High PSRR (>80 dB @ 0..50 kHz), low noise. Vin = 5.5V, Vout = 5V, IoutMax = 200mA. Dropout voltage preferably < 200 mV.
That's a problem.
Good PSRR and regulation both depend on the LDO's pass transistor characteristics. You'll get better performance if the pass device is fast, low capacitance, high gain, etc.
All these characteristics degrade significantly when dropout voltage gets below one volt. I'll use Tim's ADP7142 as example. The datasheet has a PSRR versus dropout graph:
This graph is very important! It shows excellent PSRR above 80dB over a wide frequency range, with 1V headroom or more.
However, as headroom decreases, down to 500mV in your case, PSRR drops very quickly, to about 55dB and the corner frequency drops too.
That's simply a consequence of the pass transistor getting squeezed, it'll have higher capacitance, it'll be slower, etc.
I'm not going to search for a regulator, but please keep in mind if you want low dropout and high PSRR you must check PSRR is specified at at your dropout voltage. Otherwise you'll get a surprise.
Also, high PSRR up to 50k will probably require a ferrite bead and capacitor as filter.
