c2d is used to convert a model from continuous to discrete time. The official doc states:
sysd = c2d(sysc,Ts) discretizes the continuous-time dynamic system model sysc using zero-order hold on the inputs and a sample time of Ts.
Why is it that when I do:
>> c2d(1/s, 1)
I get:
ans =
  z - 1
Sample time: 1 seconds
Discrete-time transfer function.
but according to Z-transform tables the z transform of 1/s is
ans =
    z
  z - 1
Why this discrepancy?
    \$\begingroup\$ Probably the integration method. c2d uses the zero order hold by default. Z transform table might use another method. \$\endgroup\$ – Jaywalk Feb 6 at 15:18
  • \$\begingroup\$ The Z-transform table is the result of the backward rectangular rule. \$\endgroup\$ – Suba Thomas Feb 6 at 15:36
sys = c2d (sys, tsam, method)
If you do not include the method it will use zero-order hold
c2d(G,1,'zoh')
resulting in $$ \frac{1}{z-1} $$
If you pick a different conversion method it gives you different results, but notice that the poles stability will be "conserved"
c2d(G,1,'tustin')
results in $$ \frac{0.5z+0.5}{z-1} $$
c2d(G,1,'impulse')
results in $$ \frac{z}{z-1} $$
c2d(G,1,'matched')
results in $$ \frac{1.052}{z-1} $$
| improve this answer | |
