I have some doubts about the termal noise of a real resistor.
The equivalent model of a noisy resistor is this one (here the reference):
Here there is the model of a noisy resistive network:
I have the following questions:
1) From the previous relationships for parallel and series resistances, we see that it is possible to add the noise powers of each resistor included in the network. But this is true, from a signal processing point of view, if and only if the Cross-correlation of those noises is 0, i.e. the noise of each resistor is uncorrelated with others. Why is it true?
2) Thermal noise is white noise (approximately), i.e. its power spectral density is constant with frequency. But this means that its autocorrelation is a dirac delta, i.e. a single pulse. It seems quite strange to me: I'd say that its behaviour is like the following one (which is also what I have found while searching "Time domain simulation of thermal noise"):
  • \$\begingroup\$ The resistor noises are uncorrelated and, as shown in your figure, Gaussian distributed. The probability density function (PDF) is Gaussian and the power spectral density (PSD) is white. These are independent. \$\endgroup\$
    – Ed V
    Feb 6, 2020 at 20:24
  • \$\begingroup\$ I don't think your parallel combination is anywhere near correct. You don't have two resistors in parallel -- you have a parallel combination of two series combos of a resistor with a noise source. \$\endgroup\$ Feb 6, 2020 at 21:00
    \$\begingroup\$ Is there something specific you are searching for? The autocorrelation of a temporal trace is not the PDF of the temporal trace! I gave a complete answer, but if there is still something you need to know, please say so! \$\endgroup\$
    – Ed V
    Mar 15, 2020 at 2:36
  • \$\begingroup\$ Perfect, thank you very much! \$\endgroup\$
    – Kinka-Byo
    Mar 15, 2020 at 14:04
Thermal noise is also known as Johnson noise, Nyquist noise, resistance noise and variations thereof. An excellent characterization of thermal noise is due to Davenport and Root 1: “The randomness of the thermally excited motion of free electrons in a resistor gives rise to a fluctuating voltage which appears across the terminals of the resistor. This fluctuation is known as thermal noise. Since the total noise voltage is given by the sum of a very large number of electronic voltage pulses, one might expect from the central limit theorem that the total noise voltage would be a gaussian process. This can indeed be shown to be true.”
So, the noise is gaussian distributed, as shown at the right side of the OP's second figure.
Slightly more generally, thermal noise is the noise voltage produced due to thermal motion of charged particles in conducting media. For a conductor having impedance Z, only the real part of the impedance, Re{Z}, generates thermal noise. Thermal noise is zero at absolute zero and would be zero in perfect conductors, because then Re{Z} = 0. The bilateral noise power spectral density (PSD), denoted by \$S_n(f)\$ and having units of \${V^2/Hz}\$, is given as 2:
$${S_n(f) = \frac{2Rh|f|}{e^{h|f|/kT}-1}} \tag{1}$$
where R = resistance (Ω), f = frequency (Hz), T = absolute temperature (K), h = Planck’s constant (\${6.6260755 x 10^{-34} J s}\$), and k = Boltzmann’s constant (\${1.38054 x 10^{-23} J/K}\$). Note that 1 J = 1 W/Hz.
This bilateral PSD, for R = 1000 Ω, T = 300 K, and ±60 THz around DC, is shown below:
Thermal noise PSD
The mean thermal noise voltage is zero, in compliance with the Second Law of Thermodynamics, and the variance, which equals the mean square voltage because the noise voltage has zero mean, is 2:
\${\sigma^{2} = \int\limits_{-\infty}^{\infty}S_n(f)\,df = \frac{2R(\pi kT)^2}{3h}} \tag{2}\$
This variance would be the noise power if there was no restriction on the measurement bandwidth. In fact, there must always be a restriction on measurement bandwidth. In virtually every case, the measurement system imposes a noise equivalent bandwidth that is much smaller than kT/h, e.g., for a simple RC low pass filter, the noise equivalent bandwidth is 1/4RC. At 300 K, kT/h \$\approx \$ 6.25 THz. For a 1000 Ω resistance at 300 K, the bilateral noise PSD, over ±6.25 THz around DC, is:
Thermal noise approx PSD
If measurement bandwidth << kT/h, as is very frequently the case, then h|f|/kT << 1 and \${e^{h|f|/kT} -1} \approx h|f|/kT\$. Accordingly, the rigorous expression for \${S_n(f)}\$ simplifies to:
$${S_n(f) \approx 2RkT} \tag{3}$$
which is also shown above. The conventional unilateral noise PSD, \${G_n(f)}\$, is defined as:
$${G_n(f)} = 2S_n(f) \tag{4}$$
for f ≥ 0 and zero otherwise. So \${G_n(f)}\$ is approximately 4kTR. Therefore, thermal noise, in the limit where \${h|f| << kT}\$, is white noise, i.e., noise without frequency dependence. If \${G_n(f)}\$ actually equalled 4kTR, for all frequencies, the variance would be infinite (and physically absurd).
So the autocorrelation of the approximate white PSD, i.e., the inverse Fourier transform of equation 3, is a 'delta function'. But the autocorrelation, of the temporal trace shown at the left of the OP's second figure, would be a narrow peak that approximates the 'delta' function. The inverse Fourier transform of equation 1 would give the actual autocorrelation of thermal noise.
References:
  1. W. B. Davenport, Jr., W. L. Root, An Introduction to the Theory of Random Signals and Noise, McGraw-Hill, NY, ©1958, p. 185.
  2. A. B. Carlson, Communications Systems, McGraw-Hill, NY, ©1968, p.118.
(1) the resistors are physically separate. Thus the motions of electrons jumping orbits, or jumping from atom to atom, or grain to grain, will not be correlated.
(2) The 3dB frequency for electron (thermal) noise is about 200 Terahertz, because the electron jump time is a few femto-seconds.
1) Brute force calculation brings the result for you. If you take the definition of the RMS voltage and apply it to a sum, say A+B where A and B are different random voltages, you have (A+B)^2 to be integrated, That's A^2 + 2AB + B^2. The integral of a sum is the sum of integrals. But the product AB as integrated reduces to the cross-correlation function at delay=0 and that's zero if and only if A and B are independent.
2) Autocorrelation at zero delay (or R(0)) =Dirac's delta is true for the theoretical infinite bandwidth white noise because it has infinite power and the voltage can vary infinitely fast. No simulations can have such signal.
Generally R(0)= the average power (to 1 Ohm). R(T) where T is not zero should in practice finally give something if T is small enough because limited bandwidth prevents the signal to vary infinitely fast.
I guess you should read something about stochastic processes. Every elementary communication theory book at university level uses them and very likely also explains their basics in an introductory section.
