I'm not terribly proficient when it comes to hardware, so please bear with me.
I've tried to google around to figure out how to choose values for a low pass filter to reduce noise on a potentiometer. Most of the articles I have read explain how to choose values based on frequency characteristics. That is a reasonable approach when you have that information.
In this situation, my digital input on an arduino is modulated by a potentiometer and I am seeing the values bouncing around a lot between 1 and zero when it's around the threshold. I would like to implement a low pass filter, but I am not sure how to choose my values since it's not clear to me what the frequency band I want to filter is (I do not have an oscilloscope).
This problem feels fairly simple, and so far i've seen a bunch of arduino tutorials to 'just implement a low pass filter'. But what I'm looking for is, how would an electric engineer approach choosing the right values for R and C given they are seeing a noisy analog input?
Also, this is not a question about any specific circuit I've built, this is more a general question about how to build low pass filters in practice.
Edit: Here is a bit more information.
I'm using an LM35 sensor, which operated in the \${mV}\$ range. The temperature from the sensor is \$\frac{output(mV)}{10mV}\$ so 400mV would be 40.0 degrees C. I wanted to use the potentiometer to modulate a 0-450 mV value to feed to a comparator (LM393) to determine whether the temperature is greater than some adjustable threshold. In order to set the Vcc pin of the potentiometer, I used a voltage divider \$\frac{10kΩ}{100kΩ + 10kΩ} * 5V = .454V = 454mV\$
The circuit looks like this, and \${V_{out}}\$ is going into one of the arduino digital inputs. I also feed the inputs of the comparators to analog inputs for inspection, and the potentiometer input bounces around quite a bit.
