I have this 13 pin FFC cable inside my Canon Typestar 5 thermal typewriter. It connects the LCD display to the main board. I'd like to pull the display outside the machine and for that I need an extension (not long). Do extensions exist for such cable? If so where do I find one?
PS: There is a number of posts on extending FFC cables but they are all quite technical. I just need to find an extension.
I think in your situation the easiest way would simply be to use a 13 contacts to 13 contacts board, then a new 13 pin FFC cable.
Both can be bought from common suppliers. These two are specifically from amazon.
13 pin adapter board
13 pin FFC 150mm cable
While I'm pretty sure your pitch is 1.0mm....measure it yourself to be sure.
  • \$\begingroup\$ That's very useful. Thanks. Those would have to come from China but Amazon US sell them too. \$\endgroup\$
    – JeanB
    Feb 7, 2020 at 4:19
  • \$\begingroup\$ I gave a link to the canadian site. They ship from the US. If your location is in the US then amazon.com delivers it in less than a week at most locations. amazon.com/uxcell-Extension-Connector-Aapter-Extend/dp/… amazon.com/uxcell-Flexible-Cable-Ribbon-Player/dp/B07RWPXQQB/… \$\endgroup\$
    – Natsu Kage
    Feb 7, 2020 at 4:25
  • \$\begingroup\$ Just be real sure of your pitch! \$\endgroup\$
    – Natsu Kage
    Feb 7, 2020 at 4:28
  • \$\begingroup\$ Yes, that's what I mean. The CA option takes much longer to ship. \$\endgroup\$
    – JeanB
    Feb 7, 2020 at 4:28
    \$\begingroup\$ Pitch is the distance between each pin on the cable. Measure between two metal bands on the connector, from the middle of each band. It can be 1mm, 1.25mm, 1.27mm, etc. If your pitch isn't the right one, the cable wont fit. \$\endgroup\$
    – Natsu Kage
    Feb 7, 2020 at 5:26
