6
In this question asking about the Resistance of wire, the answer by user 比尔盖子 provided the following explanation for When Resistance Can be Ignored:
Most of the time, resistance of a wire is too low when you compare it to the resistance of other components and loads, so it's negligible and often safe to ignore. Moreover, \$ V = IR \$, the lower the current a load needs to take, the higher its equivalent resistance, so you also ignore the wire resistance if the current delivered by the wire is low, because it's equivalent to connecting a small resistor (a wire) to a large resistor (a device that takes current) - almost no effect.
The first idea is clear to me: Most of the time, resistance of a wire is too low when you compare it to the resistance of other components and loads, so it's negligible and often safe to ignore. However, the second idea is unclear to me; specifically, the idea that, because \$V = IR \$, the lower the current a load needs to take, the higher its equivalent resistance, and so we can ignore the wire resistance if the current delivered by the wire is low, because it's equivalent to connecting a small resistor (a wire) to a large resistor (a device that takes current) - almost no effect. If \$V = IR \$, then, \$ V \$ being constant, a lower value of \$ I \$ implies a larger value of \$R\$ -- a larger resistance. But I don't understand why this implies that we can ignore the wire resistance if the current delivered by the wire is low.
I would appreciate it if people would please take the time to clarify this.
  • \$\begingroup\$ What usually matters is the voltage drop that the wire exhibits when carrying a current through it. For some uses, for example wiring in the home between the entrance panel and an operating vacuum cleaner, a few volts or even 10 volts of drop is okay. For some uses, 1/10th of a volt is as much as you want to accept. For still others, no more than a millivolt is allowed. Etc. Each application will have limits. But whatever those limits are, a lower current through a given wire and length will present a lower voltage drop. The lower the current, the less the voltage drop and the better that is. \$\endgroup\$
    – jonk
    Feb 7, 2020 at 7:48
10
\$V=IR\$ isn't just something you apply to the circuit as a whole. \$V\$ also isn't necessarily the voltage you're driving through the circuit. \$V=IR\$ is also how you calculate the voltage drop across a given resistance.
If our load is relatively high resistance and as a result, our current \$I\$ is small, that means the actual impact (voltage dropped) by a wire of low resistance will be quite low indeed. If we have \$5\ \mathrm V\$ powering a \$1\ \mathrm{k\Omega}\$ load, and a wire between the voltage source and that load with a total resistance of \$5\ \mathrm{m\Omega}\$, then the total current will be \$5\ \mathrm V/1000.005\ \mathrm{\Omega} = 4.999975\ \mathrm{mA}\$. This means that our \$5\ \mathrm V\$ wire, because of \$V=IR\$, will drop the voltage by: \$4.999975\ \mathrm{mA}\times0.005\ \mathrm{\Omega}=24.999875\ \mathrm{\mu V}\$. Yes, 25 microvolts.‬ Due to the wire, the load sees a voltage that is \$0.0005\ \%\$ lower than the \$5\ \mathrm V\$ it might otherwise expect.
A low current when looking at the total voltage across a circuit does indeed imply a high resistance for the entire circuit. But there is no reason to hold voltage constant, as it is not constant through our circuit, but rather it will drop by some amount after each series-connected element. The current is the same through things connected in series, so this means that each element will drop a share of the total voltage across the circuit proportional to how much of the total load it accounts for.
So when the current is low, that means the voltage dropped by something with low resistance relative to the total resistance will be a very small percentage of the total voltage. So a very small resistance in series with a very large resistance, no matter how much voltage you actually put across them, that small resistance will always only drop the voltage proportionally to how much of the total resistance that small resistance accounts for. And when that current (and thus voltage across the entire circuit) is small, then the voltage drop caused by the small resistance will be very small.
Now, there are certainly some precision applications where even a drop of microvolts is something that must be accounted for and potentially calibrated out or minimized. Platinum resistance temperature detectors (RTDs) are a great example. They're little more than a resistor, typically \$100\ \mathrm{\Omega}\$ or \$1000\ \mathrm{\Omega}\$ (roughly) at \$0\ \mathrm{^\circ C}\$, with only a fairly small change in resistance (less than \$0.5\ \mathrm{\Omega}\$ per degree for the \$100\ \mathrm{\Omega}\$ versions) vs temperature. To increase measurement accuracy, it is common to use four wires – two wires which carry the 'excitation current', usually a few \$\mathrm{mA}\$ through some series connected resistors to induce a voltage drop across the RTD, and two sense wires which connect to an amplifier with very high input impedance. This minimizes the error caused by the wire resistance in the excitation wires carrying, say, \$5\ \mathrm{mA}\$ by simply bypassing them entirely. Separate voltage sense and current carrying wires like this are common in precision equipment or very high current applications (where even low resistances of thick wires can introduce meaningful error due to the voltage drop).
So there isn't any definite threshold where it automatically becomes totally safe to ignore small parasitics like wire resistance out of hand. Only you, with knowledge of the exact application or circuit you're designing, can make that judgement call. And most of the time, most small things like this can be ignored. Just don't forget about them, because they're always there, and will impact your circuit, negligible or not.
Parasitics come in more flavors than resistance. Parasitic inductance and capacitance are always present as well. And for a bonus headache, everything conductive is an antenna and can happily receive or emit electromagnetic waves, depending on size. And everything that isn't conductive (dielectrics) will happily conduct free electromagnetic waves where conductors would absorb or reflect them. And all of these things I just described can balloon to your primary design concern depending on what you're doing.
Anything can be ignored. At least until it can't be.
    \$\begingroup\$ Note: Voltage doesn't drop before or after elements; it drops "across" elements. \$\endgroup\$
    – user253751
    Feb 7, 2020 at 15:54
As for the second idea, your assumption that V is beeing constant is wrong.
V is not constant but it is kind of "produced" by I and R. So if the current through a wire is low and resistance is not too high, then the voltage drop V across this wire will also be low.
V might be (thought of) constant for a batteries or other voltage sources, but in fact, all components/elements of the circuit like sources, resistors, wire segments, coils, ... do follow the simple V=RI rule, i.e. every element of the circuit will have a voltage drop V that "is produced" by its resistance and current flowing through it.
  • \$\begingroup\$ V can be constant if R is dynamic. Then, according to Ohm's law V = I.R, when I increases, R decreases... and V stays constant. All kinds of diodes act in this way in the vertical part of their IV curve... also the so-called "active diodes" that are actually transistors with a voltage-type negative feedback. \$\endgroup\$ Feb 7, 2020 at 8:56
  • \$\begingroup\$ Ohm's Law (V=RI) applies only to ideal resistors. In general, it does not apply to sources or coils. You can only use Ohm's Law with these elements if you explicitly and clearly model those elements as being non-ideal and having some stated series resistance. Voltage is not produced by current (in general). For a resistor, the voltage and current have a defined relationship but you can not say that one "produces" the other. \$\endgroup\$ Feb 8, 2020 at 16:26
-1
Since the current through this circuit is the same, we can present the problem both in terms of resistances and in terms of voltages. If the resistances are geometrically linear, we can present it even in terms of lenghts:
Rl/RL = Vl/VL = l/L or RL/(Rl + RL) = Vl/(Vl + VL) = l/(l + L)
