Situation:
I am doing a project which requires me to chain 25 74HC595 shift registers together. They ate controlled by an Arduino microcontroller.
Question:
- Will it work when chaining that number of shift registers together?
- Will there be any problem such as the clock signal false and data transmission errors because of the long transmission distance?
- Do I need something like a buffer or capacitor to make sure the transmitted signal is correct? If needed, any recommended type and where to connect them?
