I am working on verilog project in lattice diamond. I synthesize and compile correctly my code. I write my lpf (constraints file) to place pins,but when i try to visualize the pin/port assignment in the spreadsheet view ,i get these errors:
ERROR - The port [clk_ch1_p_i] doesn't exist in the design. ERROR - The port [d0_ch1_p_i] doesn't exist in the design. ERROR - The port [d1_ch1_p_i] doesn't exist in the design.
However these signals exist in my design and are declared in the top module. please could someone help me.
// fixed directive used in cmos2dphy
`define CSI2CSI
`define TX_CSI2
`define NUM_PIX_LANE_1
// number of dphy data lanes
`ifdef NO_OF_LANE_1  //------------
 `define NUM_RX_LANE_1
 `define NUM_TX_LANE_1
`elsif NO_OF_LANE_2  //------------
 `define NUM_RX_LANE_2
 `define NUM_TX_LANE_2
`elsif NO_OF_LANE_4  //------------
 `define NUM_RX_LANE_4
 `define NUM_TX_LANE_4
`endif
`include "compiler_directives.v"
module csi2_2_csi2_ip_wrapper
// PARAMETERS
`ifdef LATTICE_RX1
  parameter       DPHY_RX_IP_CH1   = "LATTICE",
`else
  parameter       DPHY_RX_IP_CH1   = "MIXEL",
`endif
// valid values of TX PLL parameters :
// N = 1-32
// M = 16-255
// O = 1,2,4,8
`ifdef PLL_CN
  parameter [4:0] PLL_CN           = `PLL_CN,      // N = 3
`else
  parameter [4:0] PLL_CN           = 5'b1_0000,      // N = 3
`endif
`ifdef PLL_CM
  parameter [7:0] PLL_CM           = `PLL_CM,   // M = 48
`else
  parameter [7:0] PLL_CM           = 8'b1101_0000,   // M = 48
`endif
`ifdef PLL_CO
  parameter [1:0] PLL_CO           = `PLL_CO,          // O = 1
`else
  parameter [1:0] PLL_CO           = 2'b00,          // O = 1
`endif
// parameters are set for _720__MHz MIPI RX Clk.
// refclk = _90_ MHz; byteclk = _90_ MHz
//`endif
// Virtual Channel ID assignment
// valid values are 2'd0-2'd3; cannot be the same value if cfg'd as VC merge
`ifdef VC_CH0
  parameter [1:0] VC_CH0           = `VC_CH0,
`else
  parameter [1:0] VC_CH0           = 2'b00,
`endif
`ifdef VC_CH1
  parameter [1:0] VC_CH1           = `VC_CH1,
`else
  parameter [1:0] VC_CH1           = 2'b01,
`endif
// TINIT_VALUE - slave initialization time. number of byteclk cycles before
// issuing any transaction to the slave to give it time to initialize.
// cmos2dphy parameter
`ifdef TINIT_VALUE
  parameter TINIT_VALUE=`TINIT_VALUE,
`else
  parameter TINIT_VALUE=9400,
`endif
// target tx byteclock frequency, in MHz
`ifdef TX_FREQ_TGT
  parameter TX_FREQ_TGT=`TX_FREQ_TGT
`else
  parameter TX_FREQ_TGT=93
`endif
// PORT DECLARATIONS
 input  reset_n_i,
`ifdef RX_CLK_MODE_HS_LP //~~~~~~~~~
 input  ref_clk_i, // for tx
`endif
 inout  clk_ch0_p_i,
 inout  clk_ch0_n_i,
 inout  clk_ch1_p_i,
 inout  clk_ch1_n_i,
// d0 always defined regardless of NO of LANES
 inout  d0_ch0_n_i,
 inout  d0_ch0_p_i,
 inout  d0_ch1_n_i,
 inout  d0_ch1_p_i,
`ifdef NO_OF_LANE_2 //--------
 inout  d1_ch0_n_i,
 inout  d1_ch0_p_i,
 inout  d1_ch1_n_i,
 inout  d1_ch1_p_i,
 inout  d1_ch0_n_i,
 inout  d1_ch0_p_i,
 inout  d1_ch1_n_i,
 inout  d1_ch1_p_i,
 inout  d2_ch0_n_i,
 inout  d2_ch0_p_i,
 inout  d2_ch1_n_i,
 inout  d2_ch1_p_i,
 inout  d3_ch0_n_i,
 inout  d3_ch0_p_i,
 inout  d3_ch1_n_i,
 inout  d3_ch1_p_i,
`endif //---------------------
// these signals within MISC_ON are used only for simulations
`ifdef MISC_ON //..............................
 `ifdef MISC_TXPLLLOCK
 output tx_pll_lock_o,
 `endif
 `ifdef MISC_TINITDONE
 output tinit_done_o,
 `endif
 `ifdef MISC_RX0_SPEN
 output rx0_sp_en_o,
 `endif
 `ifdef MISC_RX0_LPEN
 output rx0_lp_en_o,
 `endif
 `ifdef MISC_RX0_HSSYNC
 output rx0_hs_sync_o,
 `endif
 `ifdef MISC_RX1_SPEN
 output rx1_sp_en_o,
 `endif
 `ifdef MISC_RX1_LPEN
 output rx1_lp_en_o,
 `endif
 `ifdef MISC_RX1_HSSYNC
 output rx1_hs_sync_o,
 `endif
 `ifdef MISC_TX_FVEN
 output tx_fv_en_o,
 `endif
 `ifdef MISC_TX_LVEN
 output tx_lv_en_o,
 `endif
 `ifdef MISC_BYTEDATVLD
 output tx_byte_data_vld,
 `endif
`endif // MISC_ON .............................
 output clk_p_o,
 output clk_n_o,
`ifdef NO_OF_LANE_4 //--------
 output d3_n_o,
 output d3_p_o,
 output d2_n_o,
 output d2_p_o,
 output d1_n_o,
 output d1_p_o,
 output d1_n_o,
 output d1_p_o,
 output d0_n_o,
 output d0_p_o
// LOCAL PARAMETERS
parameter test_mode=1'b0;
/* // ANYWHERE always
 `ifdef FS_ANYWHERE
parameter FS_POSITION="ANYWHERE";
`elsif FS_1ST_PACKET
parameter FS_POSITION="1ST_PACKET";
`endif
// WAIT_LESS - dphy2cmos checks for frame start before enabling output
`ifdef TX_WAIT_LESS_15MS
parameter           TX_WAIT_TIME    = "LESS_15MS";
`elsif TX_WAIT_OVER_15MS
parameter           TX_WAIT_TIME    = "OVER_15MS";
`endif
`ifdef RX_GEAR_8
parameter           RX_GEAR         = 8;              // DPHY Rx Clock Gear
`elsif RX_GEAR_16
parameter           RX_GEAR         = 16;            // DPHY Rx Clock Gear
`endif
`ifdef TX_GEAR_8
parameter           TX_GEAR         = 8;            // DPHY Tx Clock Gear
`elsif TX_GEAR_16
parameter           TX_GEAR         = 16;            // DPHY Rx Clock Gear
`endif
`ifdef RGB888
parameter           DT              = "RGB888" ;       //  "RGB888", "RAW8", "RAW10", "RAW12", "YUV420-8", "LEGACY_YUV420_8", "YUV420_8_CSPS"
`elsif RAW8
parameter           DT              = "RAW8";
`elsif RAW10
parameter           DT              = "RAW10";
`elsif RAW12
parameter           DT              = "RAW12";
`elsif YUV420_8
parameter           DT              = "YUV420_8";
`elsif YUV422_8
parameter           DT              = "YUV422_8";
`elsif YUV420_10
parameter           DT              = "YUV420_10";
`elsif YUV422_10
parameter           DT              = "YUV422_10";
`elsif YUV420_8_CSPS
parameter           DT              = "YUV420_8_CSPS";
`elsif YUV420_10_CSPS
parameter           DT              = "YUV420_10_CSPS";
`endif
`ifdef NO_OF_LANE_1
parameter           LANE_COUNT = 1;
`elsif NO_OF_LANE_2
parameter           LANE_COUNT = 2;
`elsif NO_OF_LANE_4
parameter           LANE_COUNT = 4;
`endif
//1024 deep for lane4 cfg
parameter           LBUF_DEPTH      = 8192/`LANE_COUNT;
//RX_CLK_MODE parameter
`ifdef RX_CLK_MODE_HS_LP //..............
parameter        RX_CLK_MODE = "HS_LP";  //"HS_LP" or "HS_ONLY"
`else  // RX_CLK_MODE_HS_ONLY
parameter        RX_CLK_MODE = "HS_ONLY";
`endif
//TX_CLK_MODE parameter
`ifdef TX_CLK_MODE_HS_LP //..............
parameter        TX_CLK_MODE = "HS_LP";  //"HS_LP" or "HS_ONLY"
`else  // TX_CLK_MODE_HS_ONLY
parameter        TX_CLK_MODE = "HS_ONLY";
`endif
//TINIT_COUNT parameter
`ifdef BYPASS_TINIT //..............
parameter        TINIT_COUNT = "OFF";  //"HS_LP" or "HS_ONLY"
`else
parameter        TINIT_COUNT = "ON";
`endif
//Lane aligner enable
`ifdef LANE_ALIGN
parameter        LANE_ALIGN = "ON";
`else
parameter        LANE_ALIGN = "OFF";
`endif
// WIRE and REGISTER DECLARATIONS
wire tx_refclk;
wire pix_clk;
wire pll_clkop;
wire clk_byte_fr;
wire clk_lp_ctrl;
wire pll_lock;
wire reset_lp_n;
wire reset_byte_fr_n;
wire tinit_done_w;
// Registers for synchronizing reset to different clock domains
reg         reset_lp_n_meta;
reg         reset_lp_n_sync;
reg         reset_byte_fr_n_meta;
reg         reset_byte_fr_n_sync;
assign reset_lp_n         = reset_lp_n_sync;
assign reset_byte_fr_n    = reset_byte_fr_n_sync;
`ifdef MISC_ON
assign tinit_done_o       = tinit_done_w;
`endif
// Synchronized reset for each clock domain
////added option to use Snow PLL to avoid frequency holes of Mixel PLL
assign pix_clk   = ref_clk_i;
`else // RX_CLK_MODE_HS_LP
assign pix_clk  = clk_byte_fr;
`endif
// PROCEDURAL BLOCKS
 /*synthesis translate_off*/
 GSR GSR_INST (1'b1);
 /*synthesis translate_on*/
`ifdef USE_PLL_X2
assign tx_refclk = pll_clkop;
`elsif USE_PLL_X4
`elsif USE_PLL_X5
`else //no Snow PLL
assign tx_refclk = pix_clk;
assign pll_lock  = 1'b1;
`endif
//// Snow PLL
`ifdef USE_PLL_X2
pll_wrapper_x2 pll_wrapper_inst (
  .CLKI (pix_clk),
  .CLKOP (pll_clkop),
  .LOCK  (pll_lock)
`elsif USE_PLL_X4
pll_wrapper_x4 pll_wrapper_inst (
  .CLKI (pix_clk),
  .CLKOP (pll_clkop),
  .LOCK  (pll_lock)
`elsif USE_PLL_X5
pll_wrapper_x5 pll_wrapper_inst (
  .CLKI (pix_clk),
  .CLKOP (pll_clkop),
  .LOCK  (pll_lock)
`endif
  always @(posedge clk_lp_ctrl or negedge reset_n_i)
  begin
      if (~reset_n_i)
      begin
          reset_lp_n_meta <= 0;
          reset_lp_n_sync <= 0;
      end
      else
      begin
          reset_lp_n_meta <= reset_n_i;
          reset_lp_n_sync <= reset_lp_n_meta;
      end
  end
// tx pll is already locked before the rx can start data transfer
  always @(posedge clk_byte_fr or negedge reset_n_i)
  begin
      if (~reset_n_i)
      begin
          reset_byte_fr_n_meta <= 0;
          reset_byte_fr_n_sync <= 0;
      end
      else
      begin
        //  reset_byte_fr_n_meta <= reset_n_i & tx_pll_lock_o;
          reset_byte_fr_n_meta <= reset_n_i && tinit_done_w ;
          reset_byte_fr_n_sync <= reset_byte_fr_n_meta;
      end
  end
csi2_2_csi2_ip # (
        .RX_CLK_MODE                    (RX_CLK_MODE),
        .TX_CLK_MODE                    (TX_CLK_MODE),
        .DPHY_RX_IP_CH1                 (DPHY_RX_IP_CH1),
        .TINIT_COUNT                    (TINIT_COUNT),
        .LANE_ALIGN                     (LANE_ALIGN),
    .LANE_COUNT                     (`LANE_COUNT),
    .PLL_M                          (PLL_CM),
    .PLL_N                          (PLL_CN),
    .PLL_O                          (PLL_CO),
    .TINIT_VALUE                    (TINIT_VALUE),
    .TX_WAIT_TIME                   (TX_WAIT_TIME),
        .TX_FREQ_TGT                    (TX_FREQ_TGT),
        .RX_GEAR                        (RX_GEAR),
        .TX_GEAR                        (TX_GEAR),
        .DT                             (DT),
        .LBUF_DEPTH                     (LBUF_DEPTH),
        .VC_CH0                         (VC_CH0),
        .VC_CH1                         (VC_CH1)
    csi2csi_inst
    .reset_n_i                      (reset_n_i),
    //.reset_n_i                    (reset_n_i),
    .reset_lp_n_i                   (reset_lp_n),
    .reset_byte_fr_n_i              (reset_byte_fr_n),
    .ref_clk_i                      (ref_clk_i), // used as byteclk_fr for hs_lp gear8
////added separate port for pixel clock, added pll lock
        .pix_clk_i                      (pix_clk),
        .pll_lock_i                     (pll_lock),
        .tx_refclk_i                    (tx_refclk),
    .clk_lp_ctrl_i                  (clk_lp_ctrl),
//  .refpll_lock_i                  (pll_lock),
`ifdef RX_CLK_MODE_HS_ONLY
        .rx_byte_clk_fr_ch0             (clk_byte_fr), // from rx_byteclk_ch0
`elsif RX_CLK_MODE_HS_LP
        .tx_byte_clk_o                  (clk_byte_fr),// from tx mixel pll
`endif
        .clk_ch0_p_i                    (clk_ch0_p_i),
        .clk_ch0_n_i                    (clk_ch0_n_i),
        .clk_ch1_p_i                    (clk_ch1_p_i),
        .clk_ch1_n_i                    (clk_ch1_n_i),
    .d0_ch0_p_i                     (d0_ch0_p_i),
        .d0_ch0_n_i                     (d0_ch0_n_i),
        .d0_ch1_p_i                     (d0_ch1_p_i),
        .d0_ch1_n_i                     (d0_ch1_n_i),
        .d0_p_o                         (d0_p_o),
        .d0_n_o                         (d0_n_o),
        .d1_ch0_p_i                     (d1_ch0_p_i),
        .d1_ch0_n_i                     (d1_ch0_n_i),
        .d1_ch1_p_i                     (d1_ch1_p_i),
        .d1_ch1_n_i                     (d1_ch1_n_i),
        .d1_p_o                         (d1_p_o),
        .d1_n_o                         (d1_n_o),
        .d2_ch0_p_i                     (d2_ch0_p_i),
        .d2_ch0_n_i                     (d2_ch0_n_i),
        .d2_ch1_p_i                     (d2_ch1_p_i),
        .d2_ch1_n_i                     (d2_ch1_n_i),
        .d3_ch0_p_i                     (d3_ch0_p_i),
        .d3_ch0_n_i                     (d3_ch0_n_i),
        .d3_ch1_p_i                     (d3_ch1_p_i),
        .d3_ch1_n_i                     (d3_ch1_n_i),
        .d1_p_o                         (d1_p_o),
        .d1_n_o                         (d1_n_o),
        .d2_p_o                         (d2_p_o),
        .d2_n_o                         (d2_n_o),
        .d3_p_o                         (d3_p_o),
        .d3_n_o                         (d3_n_o),
    .clk_n_o                        (clk_n_o),
    .clk_p_o                        (clk_p_o),
    .tx_pll_lock_o                  (tx_pll_lock_o),
    .tinit_done_o                   (tinit_done_w),
    // debug port
    //.debug_state_c                (debug_state_c),
    //.debug_state_n                (debug_state_n),
//  .debug_cnt                      (debug_cnt),
    .rx0_sp_en_o                    (rx0_sp_en_o),
        .rx0_lp_en_o                    (rx0_lp_en_o),
        .rx0_hs_sync_o                  (rx0_hs_sync_o),
        .rx1_sp_en_o                    (rx1_sp_en_o),
    .rx1_lp_en_o                    (rx1_lp_en_o),
        .rx1_hs_sync_o                  (rx1_hs_sync_o),
        .tx_fv_en_o                     (tx_fv_en_o),
        .tx_lv_en_o                     (tx_lv_en_o),
        .tx_byte_data_vld               (tx_byte_data_vld)
`ifdef RX_CLK_MODE_HS_ONLY //------------------
  assign clk_lp_ctrl = 1'b1;
`else // RX_CLK_MODE_HS_LP  //-----------------
  `ifdef TX_GEAR_8
    assign clk_lp_ctrl  = ref_clk_i;
  `else
    assign clk_lp_ctrl  = clk_byte_fr;
  `endif
`endif // clk mode ----------------------------
endmodule
  • \$\begingroup\$ ... but do they exist after synthesis? If synth can trim something away because it doesn't do anything, it will. So, you need to make this port do something (if there are several, AND them together onto a spare pin or a spare bit in a register, or learn about "Keep" attributes. \$\endgroup\$ – Brian Drummond Feb 7 at 17:48
  • \$\begingroup\$ Thanks Brian. I checked and i found that effectively they don't do anything in any of modules where they are used , they are just declared and and used in module instanciations, that's maybe why they are discarded from the design. I tried the keep attribute , it doesn't work still have the same problem. Could you please explain to me more what do you mean by this : (if there are several, AND them together onto a spare pin or a spare bit in a register). Thanks again for your help \$\endgroup\$ – Y.OU Feb 10 at 9:53
  • \$\begingroup\$ I have an other question always in the same context , it is normal that these signals which are trimmed away appear in the netlist analyser ( this is where we display the entire design )? \$\endgroup\$ – Y.OU Feb 10 at 10:02
  • \$\begingroup\$ What I meant is, add some logic that DOES use these signals, and is observable somehow (but doesn't affect the important logic). That prevents trimming. \$\endgroup\$ – Brian Drummond Feb 10 at 11:26
