Why when I put even a light load on the bridge rectifier output shows 100Hz ripple?
Poor man's oscilloscope
SR240 datasheet
  • \$\begingroup\$ 16 mV peak? Is that correct? Where do you probe? \$\endgroup\$
    – winny
    Commented Feb 8, 2020 at 7:55
  • \$\begingroup\$ @winny The cheap scope shows that, so... I'm probing right on the output terminal and it only oscillates under load. \$\endgroup\$ Commented Feb 8, 2020 at 7:58
  • \$\begingroup\$ Oh! It's AC coupled. Then it makes perfect sense. \$\endgroup\$
    – winny
    Commented Feb 8, 2020 at 18:05
That's not "oscillation", that's "ripple". The capacitor discharges between the peaks of the mains, which occur 10ms apart with a 50Hz mains and a full-wave bridge rectifier.
The peak-to-peak ripple will be approximately proportional to the load current for small ripple.
See Andy's answer here
  • \$\begingroup\$ But there's 4400uF capacitors on the output, I think that should stand for example a 10mA load without any ripple, right? \$\endgroup\$ Commented Feb 8, 2020 at 8:09
    \$\begingroup\$ Any load will result in some ripple. For a 10mA load at 50Hz full wave and 4400uF I would expect around 23mVp-p. \$\endgroup\$ Commented Feb 8, 2020 at 8:12
    \$\begingroup\$ And the scope says 22 mV. That's about as good a confirmation as you get. \$\endgroup\$ Commented Feb 8, 2020 at 17:09
