I'm learning about solar panels and bought a 6V panel and a 3.7V Li-Ion battery as well as a solar battery charger, all from adafruit. I also got a boost converter thinking that the output of the circuit would be 3.7V but actually it outputs from 3.7 up to 6.8V depending on the sun. This was my mistake for not reading carefully. I need 5V at the output for a microcontroller and other components. I was looking around and found a 5V precision voltage reference REF02, but it takes a minimum of 8V input and upto 40V. So my question is, can I use a boost converter at the output of the solar charger set it up to where it won't go below 8V at the worst condition and use the REF02 to have the stable 5V? Is this a reasonable circuit or is there a better idea or better way of doing this? Thank you.
1 Answer
It sounds like what you need is a buck-boost converter. These are switching voltage regulators that can produce a stable output voltage from an input voltage that is above or below the desired output voltage.
If you want to keep things easy and just want something you can buy, Adafruit has exactly such a module. It can accept 3V-12V in and will output 5V at somewhere between 500mA and 1000mA depending on if it is in boost or buck mode.
However, more generally, if you look for 'buck-boost' converters, you will be able to find quite a few suitable modules.
\$\begingroup\$ But will the output stay at 5V or will it change as the input changes? Will I have to manually adjust the output? \$\endgroup\$ Commented Feb 8, 2020 at 19:14
\$\begingroup\$ As long as the input is within the input voltage range, the output will stay constant. For the example buck-boost and input in the range of 3V-12V will result in a regulated 5V output independent of input voltage. \$\endgroup\$– John DCommented Feb 8, 2020 at 19:19
\$\begingroup\$ @Lazaro It will stay at 5 V if you don't draw too much current from it. \$\endgroup\$ Commented Feb 8, 2020 at 19:20
