I'm trying to intuitively understand a boost converter, so I've built a variable duty-cycle oscillator circuit that can go from 1kHz to 50kHz and allows me to adjust the duty cycle from 5-95% without changing the frequency (I can change both independently). See my crappy diagram below. (Note: I take care when tuning freq vs. duty cycle to make sure the frequency of the falling edge pulses doesn't exceed the on-time of the one-shot!)
I'm using this to drive a simple nFET+coil+diode+cap boost convert, right out of wikipedia.
It is not behaving at all like the theoretical model. At 50kHz and 50% duty cycle, I expect to see 2x Vin, or 10V, instead I see 50V. When I change the duty cycle, it acts OPPOSITE: voltage goes up as the n-FET on time decreases (again, constant frequency). If I slow down the frequency the voltage shoots up to 200+V.
I'm baffled. I thought 50kHz would be enough to put the circuit in continuous mode. I even tried putting a 330uH coil on there thinking that would keep the magnetic field from depleting, but instead the voltage goes up over 300V (and blows my caps)!!
What am I missing? I thought once I hit continuous mode I would see the voltage gain adhere to the duty cycle equation and would be 2x Vin at 50%, but no combination of frequency (1k-50k Hz) or duty cycle (5-95%) seems to get me there. Instead I get these crazy high voltages. I mean it is fun blowing stuff up, but I'm trying to understand.
block diagram of my circuit
EDIT: Here's a scope picture with a load resistor (10k), 1 mH toroidal inductor (large!) and a 333 kHz 50% gate drive. The top trace is the probe of a 10 Ohm resistor from the NFET source to ground (didn't have a 1 or .1 ohm). The bottom trace is the input to the NFET's gate. I'm not using the LM339 for clock gating, I'm just driving in that lower signal to the gate. I'm not sure I'm probing correctly? 333kHz seems like an awfully high frequency for a 1mH inductor and 10k load, but I also don't see the nice charge/discharge lines @mattman was talking about.
scope
EDIT #2: Big thanks to @Mattman94 for building circuits and uploading images. I'm now in continuous mode and the output voltage matches 1/(1-D) as I vary D (mostly, the 5% error is probably due to instruments and component variations) -- Picture below. I had to use a real power supply because a battery couldn't provide the 250mA required reach the expected Vout. I didn't realize continuous mode required an inductor with a very high DC saturation. In fact, I was unaware of this device parameter, but suspected there was a difference between a 100uH tiny air-core choke and 100uH 2" long ferrite core inductor. Now I know. The current equation makes sense now. Running without a load or regulation causes high voltages because there is only a parasitic path to ground through components, which explains why when adding a load the voltage drops significantly: the circuit isn't providing enough current to maintain that voltage.
TL;DR In hindsight I knew the equations, but wasn't using common sense: loading matters, component parameters matter, and you need enough supply current. WikiPedia was missing some practical nudges.
    \$\begingroup\$ You appear to have no load and no regulation, So you are charging up the cap from the inductive kick, with nothing to limit the voltage. Why were you expecting 2*Vin? \$\endgroup\$
    – user16324
    Feb 8, 2020 at 20:04
  • \$\begingroup\$ "It is not behaving at all like the theoretical model." - which theoretical model are you using? \$\endgroup\$ Feb 8, 2020 at 20:30
  • \$\begingroup\$ @BrianDrummond ... but the wikipedia circuit has no regulator, and the load resistance is not part of the continuous mode equation, so why would load resistance matter? Wouldn't the transfer function require an R-load term in it if that were the case? this is precisely where i get confused. And if i put a regulator (comparitor + voltage divider) into the nfet gate circuit, how can i know how much current the circuit supplies to maintain Vout over Rs? The Iout is also confusing. \$\endgroup\$
    – PeterT
    Feb 8, 2020 at 20:46
  • \$\begingroup\$ Wait a sec: is the Duty Cycle the ratio of On/Total time of the NFET gate? Or is it the amount of time the Nfet Gate is toggling (e.g., gated by a control circuit)? \$\endgroup\$
    – PeterT
    Feb 8, 2020 at 20:51
    \$\begingroup\$ @PeterT I'm okay if you're okay. \$\endgroup\$
    – jonk
    Feb 9, 2020 at 0:27
From your description of the inductor, it seems like you used a filter inductor rather than a power inductor. You need an inductor that has a high DC saturation current. Something like a Murata 12RS105C. 1 mH will be easier for your experiments than 100 uH.
[Repeat of my comment, so everything is in one place: To see what is going on in the circuit, you need to measure the current in the inductor or the FET. Since you probably don't have a current probe, put a small (~0.2 ohm) resistor in series with the ground side of the FET and put a scope probe on it.]
There are many boost converter equations online. But the most basic is the inductor "charge" equation. If you put a constant current into a capacitor, the voltage increases linearly. If you put a constant voltage across an inductor, the current increases linearly (until it saturates).
You can use this equation to estimate the MOSFET ON time before saturation.
If you put a small resistor in series with the MOSFET source pin, you can see the MOSFET current. You can infer the inductor current from this.
These circuits will often have nasty ringing that can make the plots hard to interpret. You may need to add an RC snubber across the MOSFET.
Edit: And like I said in my comment, you need a load.
Edit2: Measurements on actual circuit added.
I don't have access to a current probe since I retired. I thought that I had a suitable small resistor to measure the current at the MOSFET source, but I don't. It needs to be a non-inductive resistor. But, you can use the lousy contact resistance of the breadboard to your advantage. Each contact can have a few tenths of an ohm, maybe more. So, channel 2 has 2 breadboard contacts in series, nothing else. It isn't calibrated, but you can get an idea of the signal shape.
According to the inductor equation, the current peak should be about 400 mA.
5V * 80 uS / 1 mH = 400 mA.
The circuit puts out about 18 volts with a 50% duty cycle. If you vary the duty cycle, you should be able to get it into continuous mode.
Channel 1 is the gate drive. Channel 2 is the source resistor voltage.
Edit3: Added continuous mode plot.
I increased the duty cycle until it went into continuous mode. Note that I had to increase the frequency to prevent my inductor from saturating.
  • \$\begingroup\$ I'm using a selection of coils, no resistor-like inductor elements. I'm also using a hand-wrapped E25 coil former and a 25mm/10mm enameled toroid core. Like I said I'm trying to vary every parameter to understand this. ;) ... How can I tell the DC saturation? I have several 100uH inductors that vary from heavy toroids to small resistor-sized things. Yes, I'm also seeing that nasty ringing when putting the resistor on the Source-to-Gnd of the nFet, I'm using a crusty Tek 2465A scope. I'll put on one of the beefier coils and take a picture. Thanks! \$\endgroup\$
    – PeterT
    Feb 9, 2020 at 17:33
  • \$\begingroup\$ I would start with larger value inductors and substantial loads. 100 uH needs to run at 50 kHz or so. The core manufactures have tutorials on how to design inductors and transformers. I haven't done it in a really long time, so I don't know where to look offhand. In any case, get something to work with off-the-shelf inductors before you wind any of your own. \$\endgroup\$
    – Mattman944
    Feb 9, 2020 at 18:56
    \$\begingroup\$ @PeterT - I built a similar circuit and took measurements, see my edits. I tried to make it similar to your latest setup. For a larger value inductor, you want a lower frequency. I used a 1k load, I need to keep the voltage fairly low, my MOSFET is only good to 100V (and I like a lot of margin). \$\endgroup\$
    – Mattman944
    Feb 10, 2020 at 3:44
    \$\begingroup\$ @PeterT - 10 ohms on the source is way too much, it will affect the circuit. \$\endgroup\$
    – Mattman944
    Feb 10, 2020 at 3:48
    \$\begingroup\$ @PeterT - I added a continuous mode plot. \$\endgroup\$
    – Mattman944
    Feb 10, 2020 at 16:00
From the (should have been linked) Wikipedia article on boost convertors :
If the ripple amplitude of the current is too high, the inductor may be completely discharged before the end of a whole commutation cycle. This commonly occurs under light loads.
As there is no load, there is nowhere for the inductor current to go, implying a large -dI/dT because I(L) must quickly become 0 when the switch opens, and therefore a large V.
Without a load, you cannot sustainably get into continuous mode, unless something parasitic is providing a load, e.g. by breaking down.
I suggest adding a load and understanding the loaded case, where you can get into (and out of) continuous mode, and come back to unloaded later.
  • \$\begingroup\$ Thanks for the reply. Yeah, that makes sense, if I'm dumping charge on to a cap, the only place for it to go is through the serial resistance of the cap, which is why the 200+V stays on the cap after I shut it down. I also added an LM339+voltage divider+clock-gate to the nFET input so I will add some resistance (lower than the divider network) and redo my experiments. Thanks. \$\endgroup\$
    – PeterT
    Feb 9, 2020 at 17:38
  • \$\begingroup\$ I updated my post above with a picture and scope trace. I also added a load resistor and a bigger inductor, thanks! \$\endgroup\$
    – PeterT
    Feb 10, 2020 at 2:06
