What happens if we feed an electrolytic capacitor only positive voltages while keeping the negative pin voltage lower than positive. for example positive pin 20V and negative pin 5V.
Does it affect capacitor life?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityThe cap can only see the voltage difference between its two pins. When you say "positive pin 20V and negative pin 5V" you are implying these voltages relative to GND (0V), but the cap doesn't care because it cannot see GND. How can it? No pin is connected to GND. It can only see and care about the voltage difference between its two pins.
What matters is the voltage across the capacitor. In other words, from its negative terminal to its positive terminal. As long as that voltage is within the manufacturer's limits then the capacitor will be fine.
