What's up folks?
I've been developing a project using atmega328p and avr-gcc. Recently, I've tried to configure the ADC to single sample. The codes below show my main.c, ADC.c and ADC.h
//main.c
#include <avr/io.h>
#include <stdint.h>
#include <avr/sleep.h>
#include "drivers/ADC.h"
volatile int timer_counter = 0; //value of timer_counter
volatile uint8_t converteu;
int main (void){
        CLKPR = (1<<CLKPCE); // enabling bit writing in clock divider
        CLKPR = 2; //clock divider = 4, from 8 MHz to 2 MHZ
        configure_ADC(); // clock = 62.5 KHz, AREF = AVCC, single sample
        DDRB = 7; // PB0, PB1, PB2 as output
        while(1){
           sei();
           set_sleep_mode(SLEEP_MODE_IDLE);
           sleep_mode();
//ADC.c
#include<avr/io.h>
#include<avr/interrupt.h>
ISR(ADC_vect){
        PORTB ^= 2;
void configure_ADC(){
        ADMUX |= (1<<REFS0); //short circuiting AVCC with AREF, ADC0 is the port enable to be read
        ADMUX &= ~((1<<MUX0)+(1<<MUX1)+(1<<MUX2)+(1<<MUX3)); //selecting ADC0
        ADCSRA |= (1<<ADEN); //ADC enable
        ADCSRA |= (1<<ADPS2) + (1<<ADPS0); // AVCC as reference
        ADCSRA |= (1<<ADIE); //enabling interruption
        PRR &= ~PRADC; // no low power on ADC
//ADC.h
void configure_ADC();
These code should do nothing, just configure ADC to run in single sample. However when I run it in my microcontroller, without activating ADSC (bit that starts a conversion), the PORTB 2 is activated. The only place that enables PORTB 2 is in the ADC's ISR.
The ISR is executed without activating the ADSC bit.
What's happening with this code?
  • \$\begingroup\$ What does PORTB gets activated mean? \$\endgroup\$
    – User323693
    Feb 9, 2020 at 4:41
  • \$\begingroup\$ "These code should do nothing, just configure ADC to run in single sample." - but the comment says "auto triggering enabled, trigger_event = free running"! \$\endgroup\$ Feb 9, 2020 at 7:24
  • \$\begingroup\$ The free running comment is a past configuration that I tried. I forgot to erase it. I will edit the question. \$\endgroup\$ Feb 9, 2020 at 12:40
  • \$\begingroup\$ @User323693 PORTB gets activated means that a logic one is written on the pin. \$\endgroup\$ Feb 9, 2020 at 12:42
  • \$\begingroup\$ What is teh default state of the pin? If you comment that port B Part in ADC ISR wil it still behave the same? \$\endgroup\$
    – User323693
    Feb 9, 2020 at 16:30
I guess I discovered the reason for the ISR being requested without changes in ADSC.
The Idle mode's description, in the datasheet, states:
" If the ADC is enabled, a conversion starts automatically when this mode is entered."
The idle mode is triggering the ADC.
  • \$\begingroup\$ That's good. you seem to have found the solution \$\endgroup\$
    – User323693
    Feb 10, 2020 at 3:09
