Matlab's feedback function is used to obtain the closed loop transfer function of a system. Example:
sys = feedback(sys1,sys2) returns a model object sys for the negative feedback interconnection of model objects sys1,sys2. To compute the closed-loop system with positive feedback, use sign = +1, for negative feedback we use -1.
My question arises when we have a system of the following type:
According to these docs, we can use feedback to create the negative feedback loop with G and C.
sys = feedback(G*C,-1)
This is a source of confusion, shouldn't the above be: sys = feedback(G*C,1,-1)? These are not the same.
However, looking at these docs, for a unit loop gain k, you can compute the closed-loop transfer function T using:
G = tf([.5 1.3],[1 1.2  1.6 0]);
T = feedback(G,1);
Why are we using 1 and not -1? This is still negative feedback and not positive feedback.
  • \$\begingroup\$ feedback(g, 1) gives unitary negative feedback loop. \$feedback(g, 1)=\frac{g}{1+g}\$. That’s the syntax. \$\endgroup\$ – Chu Feb 9 '20 at 12:50
  • \$\begingroup\$ So, it seems like there is a mistake in the documentation \$\endgroup\$ – rrz0 Feb 9 '20 at 14:33
