When discussing an ideal transformer, Wikipedia says “varying flux at the secondary winding induces a varying electromotive force (EMF, voltage) in the secondary winding due to electromagnetic induction and the secondary current so produced creates a flux equal and opposite to that produced by the primary winding, in accordance with Lenz's law.” It is my understanding that a real transformer experiences core losses that mean the flux created by the secondary coil is not as great as that produced by the primary. I am wondering what would happen if the flux produced by the secondary coil was actually greater than the flux produced by the primary coil.
Suppose the secondary coil in a transformer was connected to an external power source. As the voltage is induced in the secondary coil, the external power source also supplies power to the secondary coil, flowing in the same direction as the induced current/voltage. Would the flux produced by the secondary coil be stronger than the one produced by the primary, and what would happen as a result?
I am not planning on actually doing this - I just want to know if it is possible, and what would happen.
    \$\begingroup\$ Yes transformers work (to a first order approximation) equally well backwards. (Once you account for losses, this is only about 90% true. See electronics.stackexchange.com/questions/300008/… \$\endgroup\$
    – user16324
    Feb 9, 2020 at 14:59
I think there may be some misconception here. The secondary current that flows is because of the load on the secondary. This produces a flux that is entirely cancelled by the increase in primary created flux caused by that load.
In other words there is still the magnetization flux due to magnetization current. That magnetization current always flows irrespective of load or secondary currents.
Now, if the transformer was driven backwards and you observed the voltage rating on the secondary, the flux produced by those fewer turns would be the same as when it was originally energised the “intended” way.
A slightly more accurate result of the transformer being driven backwards is that the magnetization flux would be a tad less. This is because the turns ratio might be tailored to the “right” output voltage under load conditions and, due to transformer regulation issues, the secondary turns might be a tad higher. This would result in higher inductance and less magnetization current when driven backwards.
If both primary and secondary are driven in the right polarity i.e. observing the correct phase relationship between primary and secondary AND, they are driven with voltages that match the relative turns on each winding, then each winding will contribute 50 % to the magnetization flux.
If either of those “ifs” are not adhered to then you will get problems and high currents flowing in the primary and secondary but, magnetization flux will remain largely as it was when driven with a single excitation voltage.
  • \$\begingroup\$ I'm not sure you understood the OP's test. S/he's powering the primary as normal and then sucking extra current from the secondary, I think. \$\endgroup\$
    – Transistor
    Feb 9, 2020 at 15:59
  • \$\begingroup\$ Oh @Transistor you may be right. I’ll try and cover that as well... \$\endgroup\$
    Feb 9, 2020 at 16:13
  • \$\begingroup\$ I do think the answer covers all scenarios. \$\endgroup\$ Feb 9, 2020 at 21:25
  • \$\begingroup\$ @Andy aka thank you for your answer. Transistor and Marko Buršič thank you for your comments. Transistor, you are right, I am interested in putting more power into the secondary as the voltage is induced in the secondary. The net result would be that the secondary has more energy than the primary, but part of this energy comes from the the flux induced by the primary. I am not sure why anyone would actually do this - I just want to know what would happen. Thanks again everyone for contributing - I appreciate people even considering my strange question! \$\endgroup\$
    – EddieP
    Feb 11, 2020 at 7:22
  • \$\begingroup\$ The net result would be that the secondary has more energy than the primary, but part of this energy comes from the the flux induced by the primary. that doesn't appear to make much sense. Be clear about what you are trying to do rather than explaining it in couched terms. \$\endgroup\$
    Feb 11, 2020 at 8:12
