First, pardon for the absolute noob level of this question.
I want to replace a faulty tactile key on board, shown on the image below. To get it away from the machine I need to detach a connector with 4 wires marked as CR4s. Is this something that can be pulled off or does it need to be soldered? I do not want to apply force and break it.
Next I need to find a replacement for this 6x6 mm micro switch/button but that is a separate question.
Jura coffee machine
Edit: more pictures
Edit: after slightly brutal desoldering (did not have pump at hand) it indeed looks like the connections were crimped
  • \$\begingroup\$ You have to post pictures from several perspectives in high resolution. Otherwise it is unlikely to see if the connector consists of more than one injection molded parts. \$\endgroup\$ – Ariser - reinstate Monica Feb 9 at 16:15
  • \$\begingroup\$ Thanks, added pictures. The plastic seems to be monolithic. \$\endgroup\$ – Congenital Optimist Feb 9 at 16:46
  • \$\begingroup\$ there is a possibly that the indvidual wires can be unplugged from the shell ... lift one of the tabs and pull the wire gently \$\endgroup\$ – jsotola Feb 10 at 6:43
  • \$\begingroup\$ @jsotola That was good idea, didnt work though. Added picture after desoldering \$\endgroup\$ – Congenital Optimist Feb 10 at 10:42
  • \$\begingroup\$ interesting ... you can remove the shell before desoldering the pins .... looks like you removed the plated-through hole on the blue wire ... you may be able to put it back into the PCB \$\endgroup\$ – jsotola Feb 10 at 22:09
These connectors are very likely soldered in. You will have to desolder them, to remove them from the PCB. Judging from the drill sizes, it might be good to use a desoldering pump, but solder wick should work as well.
edit: they are for sure soldered in and not plugged The picture from the bottom size shows a lot of flux residue around the connector's pins. This means they were soldered manually after wave soldering. The only reason for this must be that the connector is inseparable bound to the wiring. Then it can't be inserted prior to wave soldering, because the wires were difficult to handle during wave soldering. And there was no reason to insert the connector post after wave soldering if it was somehow pluggable afterwards.
Side note (apparently making up most of my answer) You may ask, what is the purpose of such a connector? It may seem, that it adds cost compared to soldering the wires directly into the PCB. But it serves several purposes and in the end it might even save costs.
First of all, it separates the handling of the wires from soldering. Putting a stranded wire into a drill on a PCB is rather complicated for several reasons. It tends to splice, or if tinned, dimensions may vary. Instead, the terminals can be put into the board easily. The crimping the connector pins on the wires again is, once setup correctly, not an error prone procedure. It can be automated to a high degree unlike manual soldering. Also rework of crimping is comparably easy in comparison to soldering which can ruin the whole board if done without care.
Other benefits of soldered in connectors are: Alignment of wires leaving the board can be done by selecting the connector and its position without taking care of minimum bending radii and hassle using cable ties to keep the wires in line. Furthermore different wire types can be brought in line by using appropriate crimping contacts for each without changing the drill size at PCB-level.
Finally by connecting all contacts via the housing, mechanical stress on single wires is somehow distributed to all solder joints increasing reliability. The injection molded housing laying on a bigger surface on the PCB reduces momentum on solder joints allowing only lateral and vertical forces.
If it's cheaper depends on MOQ. But the other benefits should not be neglected.
  • \$\begingroup\$ Comprehensive answer! I also understood why desoldering pump could be useful, will definitely buy one now. \$\endgroup\$ – Congenital Optimist Feb 10 at 10:49
