This is my circuit
This is the way I tackled this problem:
$$ U_{e2} = 12 - I_e \cdot R_e = 12 - (2.02 \cdot 2) = 7.96 \text{ V} $$
$$ I_e = \left( 1 + \beta \right) \left( \frac{ I_C }{ \beta } \right) = \left( 1 + 100 \right) \left( \frac{ 2 \text{ mA} }{ 100 } \right) = 2.02 \text{ mA} $$
This is where I'm struggling:
$$ I_{be} = I_e - I_c = (2.02-2) \text{ mA} \rightarrow 0.02 \text{ mA} $$
I don't know how to find \$U_{be}\$ so I can find the resistance of \$R_{be}\$
I have been trying to find a tutorial and some help from several articles.
  • \$\begingroup\$ What problem??? \$\endgroup\$ – Andy aka Feb 9 at 18:39
  • \$\begingroup\$ @Andy aka, finding Ube so I have then find Rbe \$\endgroup\$ – be1995 Feb 9 at 18:44
  • \$\begingroup\$ Why on earth did you write the question as an image? It's not searchable. \$\endgroup\$ – pipe Feb 9 at 18:45
  • \$\begingroup\$ @pipe I have done it in word becuase I dont know how to paste equations here. sorry \$\endgroup\$ – be1995 Feb 9 at 18:48
  • \$\begingroup\$ Ube=0.60V @Ic=1mA so use that \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Feb 9 at 18:50
This configuration is very unstable with only 1 pull-up resistor for bias.
You can never predict Ve using assumptions of hFE due to the wide hFE tolerance and total dependence of hFE on bias voltage.
Vbe will be around to 0.65V ± 0.05 @ 2mA, if you look up many datasheets shown as typical values in the curves section @ 25'C, so it can be neglected as the uncertainty is dominated by hFE tolerance error.
All silicon transistors
Checking from a simulation.
If hFE=100 Vbe=613mV Vcc=12V, Ie=2mA, Re=2k, Rb=370k
Using formula Schematic above: Vcc-Ve = 4V = 2k/(2k+Rb/100)*12V
For Rb=370k, Vcc-Ve= 2k/(2k+3.7k)*12V = 4.2V .. close enough
but if we apply tolerance error hFE=150 Ve= 2k/(2k+2.47k)*12V= 5.36V ... wide tolerance error.
For details on Vbe vs Ic Vbe vs Ic characteristics of NPN transistor at different Vce in active region
    \$\begingroup\$ The teacher usually buys thousands of transistors and tests each one hoping to find one with Vbe= 0.7V and a beta of 100. \$\endgroup\$ – Audioguru Feb 9 at 19:48
Vbe is a range of voltages depending on the transistor type, its current and on its part number. A transistor type is germanium (Vbe= 0.2V - 0.4V) or silicon (Vbe= 0.6V - 0.75V). Your circuit has a transistor with no part number so you cannot lookup its range of Vbe.
You assumed a beta of 100 which is wrong because it is also a range that could be from 20 to 600. Its datasheet would show its range of beta.
  • \$\begingroup\$ in this case beta is 100 and lets say the transistor is 0.7V \$\endgroup\$ – be1995 Feb 9 at 18:57
  • \$\begingroup\$ I like the superbeta transistors with hFE > 2000 \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Feb 9 at 20:00
