Lets say I have a lossless coaxial cable with a characteristic impedance of 50 ohms. The length of the cable is very long compared to the the wavelength of the relevant signals on the coaxial cable. This is an obvious transmission line.
Now, lets say I attach an ordinary 50 ohm through-hole resistor to the end of the transmission line by attaching one lead of the resistor to the inner conductor of the coaxial line and the other lead of the resistor to the outer conductor. From what I have learned, this should result in no reflections in the transmission line when a source generates a signal at the other end of the coaxial cable because the transmission line is matched to the load.
In this situation, what is happening at the junction between the coaxial line and the leads of the resistor? Would the leads of the resistor (although very short) not make up a sort of transmission line with its own characteristic impedance? I know that characteristic impedance is not dependent on length of the transmission line, but if characteristic impedances do not match, there will be reflections. Why would there be no reflections?
