Reading this article I'm trying to understand this fragment where they are using a 1000:1 CT, with 0.1 V/A for a 100 ohm load.
A simple 12bit ADC will give us 2^12, or 4096 possible values. Applied to a 3300mV range, this gives us a resolution of about 0.8mV. The load pictured above has a total peak-to-peak voltage span of 1219mV, and should be about a 4.5-4.7A load. The 1219mV give us a possible 1523 values for the voltage displayed at our calculated resolution, which translates to about 3mA per ADC value when using our 100 ohm load resistor (remember: it’s RMS!).
I know that 0.8 mV comes from 3.3/4096. I think there's an error with 1523 value, since I get Adc = (1.219*4096)/3.3 = 1513.
My question is: how is the ratio 3 mA per ADC value derived?
4.6 A gives about 1219 mV.
1219 mV ---> 1513 counts
4.6 A ---> 1513 counts
??? ---> 1 count?
Ans: ~3.02 mA
