Is it possible to create a project in System Workbench for STM32 with CMSIS but without HAL library? My target microcontroller is STM32L053R8 on a Nucleo board. When I create a with HAL and delete all the files related to this library, I get a lot of errors and some source files can't see header files. Generally, I want to have clean project with CMSIS only.
\$\begingroup\$ Then just select no firmware instead of HAL when you configure the project. \$\endgroup\$– DKNguyenFeb 11, 2020 at 14:13
\$\begingroup\$ I tried that and It doesn't work. When I select the project without firmware, there is no CMSIS inside. Unless I have to add it manually. \$\endgroup\$– Marco SvizzeriFeb 13, 2020 at 6:53
\$\begingroup\$ Best tutorial with accurate setting I have found to create project in STM32CUBE IDE with CMSIS but without HAL library and it work perfectly. Link: pomad.fr/node/67 \$\endgroup\$– Manish KumarJun 23, 2021 at 16:12
1 Answer
I've found it.
In the properties of the project, you need to go to C/C++ build -> Settings -> Tool Settings -> Includes. In the Include paths (-l), remove the HAL-related directories and add a catalogue with your own prepared drivers. Save the settings.
The last step is to rebuild indexes.
