I am using PIC16F886/ 4MHz external Frequency/ timer 1 (100ms)/prescaler is 1. I am trying to turn on off LED for every 100ms. In below code I need to change any setting to get exact value. or my formula is wrong.
If I do reverse calculation me getting 20Mhz
Count=65536-((Time*FOSC)/4*Prescalar))
3A98(hex)=15000
15000=65536-(time*4XMhz)/4*1
time=0.050s
OR
Count =65536-(100mS*4Mhz)/4*1
count=34464
#include <htc.h>
#define _XTAL_FREQ 4000000
__CONFIG(FOSC_HS & WDTE_ON& PWRTE_ON & CP_OFF & BOREN_ON & LVP_OFF & CPD_OFF  & DEBUG_OFF&MCLRE_ON &BOREN_ON&FCMEN_ON &WRT_OFF);
#define LED_RX RC7
unsigned char Counter=0;
void InitController() {
//  OSCCON=0X08;
    //OSCTUNE = 0x00;
    WREN=0;
    WDTCON = 0b00010111;
    PORTA    = 0b00000000;
    TRISA    = 0b00111000;
    TRISB =0b00001000;
    PORTB = 0b00000000;
    WPUB    = 0b00000000;
    ANSEL  = 0b00000000;
    ADCON0  = 0b00000000;
    TRISC = 0X00;
    PORTC = 0b00000000;
    ANSELH = 0b00000000;
    ADDEN  = 0;
    //T1OSCEN = 0;
    //INTEDG = 0; //falling edge
    //INTF = 0;
    //INTE = 1;
    PIE1=0b00000001;
    PIR1=0x01;
    INTCON = 0;
    //T1CON  = 0b00000101;
    T1CON=0X15;
    TMR1IE = 1;
    PEIE   = 1;
    GIE    = 1;
//                              Main program starts here.
void main(void) {
    unsigned char value;
    unsigned char conter = 0;
    InitController();
    while(1) {
//                              Timer Interrupt - 5mSec
void interrupt isr(void) {
    asm("clrwdt");
    if (TMR1IF) {
        TMR1IF = 0;
        //  TMR1H = 0x3A;
        //  TMR1L = 0x98;
        TMR1H = 0x0B;
        TMR1L = 0xDB;
        Counter++;
        if(Counter>1) {
            Counter=0;
            LED_RX=!LED_RX;
  • \$\begingroup\$ Your Timer is working with Fosc/4 which means 1MHz \$\endgroup\$
    – Mike
    Commented Feb 12, 2020 at 11:45
Lets analyse your configuration:
T1CON=0x15
Referring to p79 of the datasheet this means
  • Prescaler=1
  • Clock=FOSC/4
  • Sync=Disable harmless but ignored
  • Timer=enabled
... as Mike commented, if your FOSC is 4MHz then you're driving the timer with a 1MHz clock.
Your formula could do with some more brackets:
Count=65536-((Time*(FOSC/4))/Prescaler)
You want to flip the LED every 0.1s but you can't request the timer to count 100000 because it's only 16 bits. Great time to use the prescaler (that's what it's for) but instead you're counting 50000/0.05s and ignoring alternate interrupts. This happens here
    Counter++;
    if(Counter>1) {
        Counter=0;
        LED_RX=!LED_RX;
Note that on the first interrupt counter goes from 0 to 1 then on the second interrupt it goes 1 to 2 (i.e. greater than 1) resets to 0 and flips the LED.
Finally, this line is plain wrong
3A98(hex)=15000=65536-(time*4XMhz)/4*1
FOSC=4e6, time=0.05s so 65336-((0.05*(4e6/4))/1)=15336=0x3BE8
