I recently took out the windings from an old microwave oven transformer and was planning to use the core for a 120 to 6.3 VAC step-down transformer (total power 160 W max).
The secondary winding (which carries the 6.3 V and 25 A) is a 12 AWG wire (shown in yellow). I noticed that the loop wasn't able to stay tightly wrapped around the core.
Is the secondary loop too large for my transformer?
Before it's brought up, I am aware that the primary loop has yet to be attached.
If you're going to use a MOT as a 'normal' transformer, then be aware it's been optimised to the max for low cost and high power output, when blown with a fan. This results in the flux and consequently the magnetising current being very high, comparable with the load current. It's good to put another 25 primary turns on (50 outside the US) to reduce the target volts/turn and hence magnetising current.
It's really difficult to reclose a MOT core and get good small airgaps in the iron path. Excessive airgaps will mean yet higher magnetisation current. If you're winding a low voltage transformer, then the best method when you salvage your next MOT is to leave the core intact, and cut off the HV winding with a saw. Having knocked out the shunts, wind the new secondary by threading plastic-insulated wire through the core, it's only a few turns. Add as many of the extra 25 primary turns as you can be bothered to by the same method.
To answer your question, as long as the wire passes through the hole in the iron, it doesn't matter where in the iron window it is. Excess length of the turn won't affect the off-load voltage, but the extra resistance will cause a lower on-load voltage because of IR volt drop.
As long as it is wound through the core the wire position doesn't much matter.
Getting a closed magnetic circuit (through the core pieces) matters a lot.
  • \$\begingroup\$ Thank you for your response. Should I be putting anything in between the primary and secondary wires to act as a barrier? \$\endgroup\$
    – user154046
    Commented Feb 13, 2020 at 3:20
  • \$\begingroup\$ 8mm of creepage is a good rule of thumb. Your secondary wire may be rated to mains voltage but putting something in there that won't melt on overload (eg. fiberglass) would be good. \$\endgroup\$ Commented Feb 13, 2020 at 3:25
