-2
I have obtained this eye diagram for a 50 Km 16 channel WDM simulation using RZ line coding.
Is this eye diagram OK or not?
What should be changed?
Thanks in advance.
New contributor
ZH S is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
  • 5
    \$\begingroup\$ I think the diagram colours could be changed and maybe have a pink background. \$\endgroup\$ – Andy aka Feb 14 at 10:02
    \$\begingroup\$ Asking if "something is OK or not" requires that you define what is "OK". Say you ask me to buy a ladder. So I buy a ladder. The ladder is too short for what you intended to do with it. For me the ladder is OK because it is cheap. For you it was not OK as it is too short. When asking for a ladder, maybe you should have mentioned what you wanted to achieve and that the ladder needs to have a certain lenght. Same with the plot, it can be OK or not depending on the definition of what is OK. So for Andy it is not OK because of the colors. I don't like the two different Y-axis scales \$\endgroup\$ – Bimpelrekkie Feb 14 at 10:07
  • \$\begingroup\$ There is a big gap between the high and low voltages halfway through the bit period. That is usually what you want on an eye diagram. Are they the correct voltages? I have no idea. Is the gap supposed to be at the bit period instead of halfway between? I have no idea either. \$\endgroup\$ – user253751 Feb 14 at 10:36
  • \$\begingroup\$ Top of that eye looks really “unsure of it wants to be a one”. \$\endgroup\$ – KingDuken Feb 14 at 15:31
ZH S is a new contributor. Be nice, and check out our Code of Conduct.
