Please help me find the current across all the resistors using mesh analysis of the given circuit
New contributor
Adhip Bhattarai is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
  • 6
    \$\begingroup\$ I'm voting to close this question as off-topic because it is homework with no attempt at a solution. Sorry, but this isn't a free homework service. You need to edit your question to show your work so far and where you are stuck. That will require you to write equations and to mark the current loops and voltages on your diagram. The first thing to do is to give designators, V1, I1, R1, R2, etc., to every component. \$\endgroup\$ – Transistor Feb 14 at 13:45
  • \$\begingroup\$ You can use the schematic button on the editor toolbar to generate the schematics (double-click the components to edit them) or upload a good quality, cropped photo of a hand-drawn solution. \$\endgroup\$ – Transistor Feb 14 at 13:46
