(This is my first post go easy on me)
I'm trying to use an OTA to simulate a floating voltage controlled resister like explained here, but I cannot for the life of me figure out how the mota model functions.
I'm aware of the general idea of an OTA. Differential input, biasing current multiplier, etc. But I cannot get the model in LTspice to function properly. I thought at first that I was supposed to connect a voltage to the bottom left I/O pin, but then I figured out it was a ground reference...
I'm having trouble getting any output from the OTA, and the current doesn't seem to be entering the biasing input.
Any and all help would be appreciated!
LTspice Simulation
Green V(n010): Differential voltage measured from negative input to positive input
Blue V(n015): Output node of OTA
Red I(R10): Current through R10 (supposedly biasing output current, but not working)
  • \$\begingroup\$ What parameters have you passed to the OTA? See this for more info, if in doubt. Also, R10 is useless, the pin does not draw current. \$\endgroup\$ Commented Feb 14, 2020 at 16:53
Since you are using the ota, then maybe you are not looking for a real-life case, instead, you want a behavioural model. If so, the simplest voltage dependent resistor is the behavioural resistor:
R1 nodeA nodeB R=f( V(control) )
where V(control) is the controlling voltage and f(x) is an optional function of your choice. Being a behavioural element, it has advantages and disadvantages.
Another approach, a bit more involved, but without the behavioural resistor, is using this:
alt
The circuit on the left is the "engine": Iref generates a unity current over S1 (a VCSW), generating a voltage. This is then compared with a reference voltage, Vref, who represents the desired time varying resistance. The difference goes through an error amplifier and a loop filter (Gfb and Cfb), generating a controlling voltage for the switch. This voltage can control any other switch in the schematic (like S2) that needs a varying resistance as supplied by Vref.
It's not perfect, either: the bandwidth is limited by the time constant of Cfb and its series resistance (1 \$\Omega\$, thus only Cfb's value matters -- Rpar is there just for a DC path to ground), the on/off values of the switche's resistances are the lower/upper limits of its variance, and, not lastly, the number of elements/nodes. OTOH, it's blazingly fast, despite this last shortcoming.
As for the OTA, here are three ways to use it, based on various parameter settings:
ota
A1 uses iout, which means symmetric, tanh() limited output (black trace), A2 uses different isrc and isink for asymmetric, tanh() limited output (blue trace), and A3 uses the linear flag, which means that any voltage going beyond the limits will have the gain halved (red trace). All are compared to the normal V(a)*V(b) (gren trace).
  • \$\begingroup\$ Thank you! I found the list of parameters for OTA's on the wiki and added the few you had in A2. \$\endgroup\$
    – Owaller
    Commented Feb 14, 2020 at 20:56
