I have an inverter that converts 24 V DC to a 48 VAC peak-to-peak square wave with a frequency of 55 Hz. I am then going to use a step-up transformer to output 120 VAC to power some rocket valves that take maximum 150 VA.
We are not sure which ones we are using yet, but I want to provide 150 VA to make sure.
My approach was to use an active wide band pass filter to convert the square wave into a sine wave. The schematic has a first order high pass filter, a non-inverting amplifier that controls the gain, and a low pass filter.
I set the HPF's cutoff frequency to be 50 Hz (\$f_o = 1/(2*\pi*R*C) \$ for a first order filter) and the LPF to be 60 Hz. I also set the gain to be 1 by setting \$ R_4 = 1M\$ and \$R_3=100 \$.
What is wrong in this setup? Why is the output sine not a perfect wave? And if this op-amp cannot provide the inrush current needed, what circuit is capable of preserving power while converting this square into a sine?
