I'm routing traces between a microcontroller and a TFT display (24-bit RGB, clock frequency at 18 MHz).The stackup is:
- L1 - Signal
- L2 - GND (solid layer)
- L3 - PWR (solid 3.3V in the region of interest)
- L4 - Signal
Components are only on top in order to reduce manufacturing cost (it also explains the choice of a 4-layer stackup).
I designed a first version of this board which worked fine and allowed to develop and test all the software. Now, I'm currently designing a new board version which some mechanical constraints. Some signals were a bit noisy but display worked fine. I would like to improve the routing a bit.
I see two different strategies to route the signals between the MCU and the display. I guess it is understandable that I cannot route only on the top layer even though it would be ideal... The screenshots below are only first drafts and not layout for production.
- Option 1 : that is the option I used in the first boards, vias are both on the MCU side and on the connector side (just before the network of 0 ohm resistors)
- Option 2 : vias are concentrated around the MCU.The goal was to have the return current path goes through the MCU decoupling capacitors to jump from the 3.3V plane to the ground plane.
Questions:
- Is any of these options better from the point of view of signal integrity/EMC?
- Option 2 makes me want to have a ground area within the power plane (L3) and vias between L2 (ground plane) and L3(ground area within power plane), so the return current path can freely jump from L3 to L2 and the other way around (see picture below) Is it something which would make sense? I've never seen such a design choice in other PCB layouts but I didn't see people routing TFT display on L4 PCB either.
- Is there a better way to solve it?
EDIT 1: Even though the question is not about length matching, I give the numbers here to justify why I didn't do any length tuning.
Clock frequency < 18 MHz <=> Period > 55 ns
For a signal speed in PCB is 15 cm/ns and an allowable skew of a quarter of the period, it gives 2 meters. I believe the mismatch of 3 cm in the examples above is not important.
EDIT 2: Quick measurement of a data line (purple) and a clock line (yellow) on the current board with a screen connected and running (it is not a proper 10/90% measurement). I don't really trust these numbers because it is a 100 MHz scope with a 100 MHz probe (20 pF probe). However, it seems to fullfil the 12 ns setup and hold time requested for the screen. Drive strength on the MCU is at the lowest settings (it divides the rising time by two at the highest setting but it introduces some ringing as much as the scope can tell).
This figure is from the first revision of the board with a layout close to option 1 but with signal lengths 3 cm shorter and a mismatch between lines of 3 cm. Screenshot below.
EDIT 3: CONCLUSION (EMC testing for CE mark)
Since my last edit, we had the board manufactured. We went for the simplest way possible. We didn't length match the signals, we didn't use controlled impedance PCB, we had a solid ground plane in L2, solid 3.3 V plane in L3. We routed based on option 2 with the vias close to the MCU. Testpoints were added on the bottom of the PCB for each line (for testing with a bed of nails).
The board was functional. We had the chance to go through EMC tests for the CE mark (for home products). The board passed the radiative immunity tests (criterion A since everything was functional) and the radiative emission tests (30 MHz to 400 MHz). Some harmonics from the 25 MHz oscillator (used for the MCU) was actually visible (starting at 425 MHz, 450 MHz, 475 MHz, etc.) and not far from the limits for the CE mark. After some testing, the problem seemed to be gone without the screen connected to the board. We ended up replacing the O ohm resistors on the RGB and clock lines by some ferrite beads. That gave us an extra margin of 5 dBV/m on the worst peak.
Norms used for CE marking:
- for radiative emission tests: EN 61000-6-3
- for radiative immunity tests: EN 61000-4-3
I cannot tell that the board was routed the best way possible but it seems to be enough for our requirements. I hope this result will be useful to other people.
