I want to know how to calculate Vgs , assuming load current Id is constant , Vd = voltage of battery is constant , and fet is operating in thermal stability region , so there is no thermal runnawy , connecting gate to ground leads us having
Vgs = - Vs , so we need to calculate Vs
Vds = Vd - Vs = V battery - Vs = Ids Rds
so how to measure Rds ? i know it is dependent on temperature
but measuring temperature in thermal stability will be difficult , as temp increase Ids decreases so temp decrease until certain point so no change after that , so the temp that it will settle at is what matters
can i assume max Rds to know min Vgs ? is there anoghter approach to control mosfet ?
update :
after reading :
i know that there is safe operating area,
assuming Ron on limit i did these calculations below
**is it right? or should i assume that Vgs = 10 Volt at max Rds
when to use Rds on limit and Max power line limit ?**
update 2 :
