I am still trying to build a simple audio amplifier using the LM386. I also found some older LM386 in my department, since my previous batch may be corrupted.
Using this circuit I rebuilt it using a breadboard.
On the Pin5_OUT are headphones and an oscilloscope. The circuit is powered with the 5V output of an Arduino Nano.
Measuring key points:
- V_pin5out = 0.825V (better than the 0V from my previous circuits, but still not 2.5V)
- V_DD = 4.71V (between the 5V pin of the arduino and GND)
- V_pin6 = 4.65V (supply pin of the chip).
There is still no audible output from the headphones and in addition the chip gets extremely hot (I pulled the plug at around 80°C).
Is there an error in my the circuit (picture above)?
Are these normal operating conditions?
Are the 2.5V bias measured only at low noises and change with the volume?
EDIT: I draw a schematic as I see the board, since the picture seems to be confusing
