I'm using an ATtiny13 running at 1.2 MHz and would like to generate a 40 kHz square wave on PB3 and PB4. The signal on PB4 should be 180 degrees offset (inverted) from PB3.
I know that I need to set certain registers to achieve this, but I do not know which registers or which values they need to be set at.
Any help with the code would be appreciated.
Update:
Thank you for the help so far. This is what I have got:
void setup() {
// Disable all interrupts
TIMSK0 |= (0<< OCIE0B) | (0<<OCIE0A) | (0<<TOIE0);
// Define outputs
DDRB = (1<<DDB4) | (1<<DDB3) | (1<<DDB2) | (1<<DDB1) | (1<<DDB0);
// Enable CTC
TCCR0A |= (1<<WGM01) | (0<<WGM00);
TCCR0B |= (0<<WGM02);
// 1.2MHz / 40kHz
OCR0A = 30;
OCR0B = 30;
// Toggle on Compare Match
TCCR0A |= (0<<COM0A1) | (1<<COM0A0) | (0<<COM0B1) | (1<<COM0B0);
// No prescaler
TCCR0B |= (0<<CS02) | (0<<CS02) | (1<<CS00);
// Make it start
GTCCR |= (1<<PSR10);
// Force one invert
TCCR0B |= (1<<FOC0B);
void loop() {
With this code, I am getting an 18.5 kHz signal on PB2 and PB1, with a 180 degree phase shift between them.
Does the code look correct or have I missed something? If I play around with the OCR0A and OCR0B values, I might be able to get the desired 40 kHz. However I should not have to do that, since 30 should be the correct value if the microcontroller is running at 1.2 MHz.
Any ideas?
