I'm trying to use a P7504 ($$$) "TriMode" scope probe, and unfortunately the resistors eventually break. Does anyone have recommendations for a 100ohm resistor that would replace the ones on the probe? A new set of just ends is $1600
\$\begingroup\$ For a $1600 probe? Might as well go with the best and I don't know resistors that are more precise or stable than metal foil resistors. \$\endgroup\$– DKNguyenFeb 18, 2020 at 21:45
\$\begingroup\$ I have used a similar Tek probe. For a 4 GHz probe, many parameters of the resistor may be critical. If I was making critical measurements, I would only use the exact resistor. \$\endgroup\$– Mattman944Feb 18, 2020 at 22:09
\$\begingroup\$ Yes, that is why I reached out to ask what resistors are ideal to replace the ones on the probe :) \$\endgroup\$– DrewsterFeb 19, 2020 at 16:41
1 Answer
That's a 4GHz probe. This Vishay app note on high frequency parasitics may be of use.
One could imagine attaching wires to an 0402 resistor and adding a bit of epoxy... but..
A set of 50 ea. 100 ohm + 50 ea. 75 ohm appears to be a mere $700 from Tektronix. 020-2937-00
1\$\begingroup\$ Thank you, Spehro - half the price of the probe kit for 50 of the resistors we actually need sounds more in-line with what we need. Hopefully this helps someone else, too \$\endgroup\$– DrewsterFeb 19, 2020 at 16:42
