The following is an example of a Logic-And gate using two spst switches:
What is the most common schematic to show a logic-and gate (without the symbol itself)? I have come across various schematics showing input nodes A and B (with nothing connected to it), but I'm not sure how those would be shown in a schematic to simulate the on/off states of those inputs. Additionally, how does one usually show that a logic gate's output is either in the On or Off position, or is this usually not done in a schematic (I've used an LED below but this is more to show myself that the and-operation is working correctly).
  • \$\begingroup\$ Your question doesn't make sense. \$\endgroup\$
    – DKNguyen
    Feb 18 '20 at 21:54
    \$\begingroup\$ Aaarrrgggh! Earth symbols should be pointing to the Earth. The symbol represents metal plates buried in the ground. \$\endgroup\$
    – Transistor
    Feb 18 '20 at 22:09
Figure 1. Function Block Diagram (FBD) is popular in some PLC programming languages, with Germans particularly fond of it. Image source: Science Direct.
I think we'd need an example from you.
Additionally, how does one usually show that a logic gate's output is either in the On or Off position, ...
Figure 2. Siemens LOGO! program status monitoring. (Click for full-scale view.) Image source: Treffpunkt Eltern.
In this example logic status is indicated by colour.
