RJ45 to 8 pos board connector. Board connector width: 12,4 mm Pin pitch: 2 mm
Found inside a plastic card printer. Somewhere to purchase cable? Identification of the board connector?
  • 4
    \$\begingroup\$ I see the question was down-voted and also there are currently three votes to close. But isn't this at least a valid component ID question? Please consider if maybe we are being too rash to close and downvote this question. \$\endgroup\$ – mkeith Feb 19 at 2:20
  • \$\begingroup\$ Custom but relatively easy to reproduce if you can identify a near enough (6 not 8 way) JST conn. \$\endgroup\$ – Brian Drummond Feb 19 at 11:18
  • \$\begingroup\$ if you can produce set of higher resolution pictures from all faces of this connector, maybe someone can identify the manufacturer. \$\endgroup\$ – Ariser Feb 20 at 5:21
the board connector looks like JST PH series
The rest of the cable looks like half of a T568B CAT5 patch calble
the presence of un-used conductors in the cable makes this almost certainnly custom. someone has cut a patch cable in half and connected five of the conductors to the JST connector, trimmed the others back and put heat-shrink over that.
| improve this answer | |
