I am breadboarding a circuit using a TL082CP Op-Amp, and I am reading consistent values with the multimeter.
The Op-Amp stage is powered with a single 9V battery, like this:
The Op-Amp stage looks like this:
However, a thing is making me scratch my head: If there is no input signal, I would expect to read around 4,5V at the non-inverting input and at the output of the Op-Amp, but actually if I measure with the multimeter the voltage between the + pin and the GND, I read around 2,5V, while the output is consistently at 4,5V.
Why is that?
I measured the voltage across the R4 resistor and it was 0V, so there must be no current on that; I tried to use a 10K resistor instead of a 470K, and then on the + pin I read around 4,5, so it must be that some sort of current is flowing at the input of the op-amp, and a bigger resistor just causes a voltage drop with that current. Am I wrong?
Is that current coming from the power stage or is it coming from the Op-Amp?
I also tried to disconnect the Op-Amp to see if the C5 capacitor was leaking, but it seemed to work fine. I am kind of inexperienced with Op-Amps, and maybe I am doing a very basic error in measuring or breadboarding, but what confuses me is that the output of the circuit seems to be correct. I would greatly appreciate your help.
