I studied several topics and sources on the net, besides Adafruit's own, and decided to try designing my own circuit.
My goal is to develop the prototype of a robot/drone that does not require me to go into surface-mounting and soldering small parts like, for example, the Texas Instruments BQ**** series.
The prototype in question is a low-powered drone of sorts and I have to be conscious of weight. Therefore I am contemplating putting all the charging circuitry into the base-station, at the price of having to lead more wires to my custom charger plug.
The "must-haves" I identified are:
- provide at least 5 V power to load while charging
- have Lipo cells in series, to provide at least 7 V power when not charging
- have high power efficiency while away from the base-station
- the mobile part of this prototype should be reasonably light-weight
I am not restricted about what voltage the base-station could provide.
I simulated the part of my circuit that disconnects the batteries when a GPIO-pin is set to high and that seems to work (though I get about 2 V voltage drop, which is really not great).
My question is:
- Do you think it is a good idea to keep pursuing this general design?
- If not, do you see a more integrated alternative for charging that does not require me to go into surface-mount-soldering? Or should I bite that bullet?
- Do you see any obvious beginner mistakes in the circuit shown here?
