How is the (dis)charging process of capacitors in series calculated?
I know that $$C_{total}=\frac1{\frac{1}{C_1}+\frac{1}{C_2}+\frac{1}{C_3}+...}$$ $$Q_{total}=Q_{1}=Q_{2}=Q_{3}=...$$ $$V_{1/2/3}=\frac{Q_{total}}{C_{1/2/3}}$$ I also know that $$V(t)=V_0*(1-e^{\frac{-t}{R*C}})$$ $$I(t)=\frac{V_0}{R}*e^{\frac{-t}{R*C}}$$ My goal is to calculate the voltage progression while (dis)charging two capacitors in series. Is that even possible or is this process too random to be calculated?
Note that i do not want to calculate the behaviour of the capacitive electronic component the two capacitors form together. Instead I want to know the voltage drop at each capacitor (, their charge and the electric current flowing through them) at any point in time.
Hopefully this is an achievable task and not connected to excessive testing and measuring.
Thank You in Advance
