Let's consider this basic scheme of voltage regulator (here the reference):
I wanted to verify that a sudden variation of the output voltage is compensated by the circuit. Suppose that the output voltage Uout increases, what happens to the current through Rv and the base current of the transistor? Can you explain me what happens step by step?
If its aim is that of generating a stable output voltage signal, the transistor should react in order to decrease Uout.
    \$\begingroup\$ Voltage regulators are usually used to maintain constant voltage during variations in current rather than variations in output voltage. \$\endgroup\$ – Transistor Feb 19 at 19:03
    \$\begingroup\$ Do you know how a Zener diode shunt voltage regulator works? \$\endgroup\$ – G36 Feb 19 at 19:16
Because the base emitter is always forward biased it acts like a diode and therefore, the emitter is slightly below the base voltage. We can analyse the base emitter junction like a diode even though we know it’s part of a BJT; it’s actually very fundamentally to the regulation properties as hopefully you will see.
Let’s say the emitter is 0.6 volts below the base. Because B-E is a diode, we can think about how much current is flowing into the base given what we know about diodes. Here’s the 1N4148 as an example: -
At 0.6 volts, the diode conducts about 1 mA
If the emitter voltage fell by (say) 100 mV (due to load changes) AND the base voltage remained constant (due to a very “perfect” zener diode at the base), the change in base current would be from 1 mA to about 6 mA and that’s a pretty decent change of current into the base.
That change in current is multiplied by hFE (say 100) and about 500 mA extra is dumped into the emitter resistor. This (largely) has the effect of countering that change in emitter voltage and, this is negative feedback and the beauty of the “emitter follower”.
Compare the above scenario with a BJT having a hFE of exactly 100 and with a constant 1 mA feeding the base. The emitter current would be 100 mA and this would entirely suit a 100 ohm emitter resistor requiring 10 volts across it.
However, if that load resistor changed to 90 ohms, due to the constant 1 mA base current (and fixed hFE), the emitter voltage has to drop to 9 volts. A poor regulator.
It is the non linear behaviour of the base emitter diode that produces such a decent regulation figure even though it’s a simple and single BJT.
what does it happen to the current through Rv
Rv is immaterial because, it’s there just to keep the zener voltage constant and my words above have assumed that it is constant.
|improve this answer|||||
