6
B
Here is the datasheet
I realize that the converter has to "work harder" to boost a voltage from 2.8V-6V to 48V than it does from 8V-38V to 48V, but I'm curious why there's such a significant drop in the efficiency in the first configuration below 10mA when there isn't a similar drop in the lower configuration. Do boost converters have a certain attribute that doesn't allow high efficiency at low currents? Are some boost converters designed to maximize the efficiency at high boost voltages and low currents?
  • \$\begingroup\$ Good question, now I'm curious as well. It could be because the first one operates in discontinuous conduction mode, which IIRC is less efficient. But I may be wrong :) \$\endgroup\$
    – anrieff
    Feb 20, 2020 at 8:01
  • \$\begingroup\$ @anrieff I as looking at that (DCM vs CM) as well but could not find a reason why the IC would not change modes so in both cases it should use DCM or CM whatever is better. So the difference must be in the inductor values, see my answer below. \$\endgroup\$ Feb 20, 2020 at 8:37
7
I'm going to call the lower input voltage range but less efficiency circuit, circuit A.
I'm going to call the more efficient configuration, circuit B.
Note that both circuits are actually the same, only some component values are different:
  • The inductor L1: 0.33 uH (circuit A) vs 6.8 uH (circuit B)
  • The RC network connected to the Vc pin
These two changes are relates, the RC network on the Vc pin influences the voltage regulation feedback loop. The inductor is also part in this loop so if its value is changed then the RC network could require a change as well.
But the main difference is in the inductor L1.
This type of DCDC converter works by charging an inductor (magnetic flux is stored), by connecting a voltage across it (the input voltage). During charging the current will ramp up (linearly). This ramp will be more steep (faster current increase) when the inductor has a smaller value (circuit A).
Inside the IC there's a switching transistor (NMOS M1, page 8 of the datasheet) and this NMOS will have a certain on resistance (\$R_{DS,on}\$). As the current through this switch is higher, more voltage is dropped and more power is lost. So high value charging currents cause inefficiency. There's also the current sense resistor making things worse.
So from this we can conclude that a large charging current will decrease the efficiency. So which circuit will have the higher charging current? Then we have to look at the value of the inductor which is the smallest in circuit A. At the same input voltage circuit A should be the least efficient then.
So why not simply increase the value of the inductor and enjoy a better efficiency?
Yes, that is an option however, as always that has other consequences. Suppose that the input voltage is low but at the same time the demanded load current at the output is significant. Then enough power must be transferred from input to output.
To be able to draw enough power from the input a small value inductor is needed. If a larger value inductor was used the current will ramp up more slowly and less energy is stored in a given amount of time.
So yes you can use a larger value inductor and get better efficiency but then the maximum output current will be smaller. Note how the Efficiency plot for circuit A has an X-axis from 0 to 30 mA while the one for circuit B is from 1 mA to 1 A.
The load current for circuit A needs to be quite small, up to 25 mA only. That is a result of the large \$\frac{V_{out}}{V_{in}}\$ ratio. That is always a challenge (resulting in lower effciency) with this type of converter.
To get better efficiency you can check out the Flyback converter which uses a transformer to aid with large \$\frac{V_{out}}{V_{in}}\$ ratios. Mains adapters mainly use flyback converters to efficiently convert a high \$V_{in}\$ to a low \$V_{out}\$ (and provide mains isolation on the go) but the same principle can be used to convert a low \$V_{in}\$ to a high \$V_{out}\$.
  • \$\begingroup\$ I believe a large inductor can still store as much energy as you want, it will just take longer to get there. However, I notice that the first circuit says "in DCM". In Discontinuous Conduction Mode (DCM), the inductor must charge up from scratch in every cycle, so in DCM, a bigger inductor can't store as much energy at the same switching frequency. The opposite of DCM, CCM, has a minimum load current. \$\endgroup\$
    – user253751
    Feb 20, 2020 at 16:23
  • \$\begingroup\$ @user253751 Yeah, I believe it affects the transient response not the actual maximum power. \$\endgroup\$
    – DKNguyen
    Feb 20, 2020 at 23:20
  • \$\begingroup\$ @Bimpelrekkie Thanks for the thorough answer. Could you elaborate why a larger value inductor would limit the maximum output current? I've never heard of that and I'm curious about your experience with it. Also, could you take a crack at explaining what causes the difference in the shape of the efficiency curves between the two graphs at low currents? \$\endgroup\$ Feb 21, 2020 at 6:56
Lower input voltage results in larger current switching to generate same output power. This simply means more loss in the inductor and transistor.
Also note the output power is much larger for the higher voltage input, thus offsetting the IC static and dynamic current.
A larger step up ratio is less efficient because the power stage has to handle much more current through the inductor and mosfet. This results in higher switching losses in the mosfet and higher conduction losses in the mosfet and inductor.
At light loads, the quiescent current of the regulator becomes significant. So efficiency suffers. This does not mean that regulation is poor. Similar to a car with a big engine requiring more fuel even when it is idling or moving slow.
The design with the larger inductor allows the regulator to switch less often at light loads. Between switching events the regulator got into low power standby. It monitors the output, and after a small droop the regulator wakes up briefly and boosts the output back up. This is called burst mode. Similar to a car with automatic start stop to prevent idling.
The LT836x family is known for its low quiescent current, and for its ability to switch fast. This helps light loads efficiency, let's you use small inductors and more easily pass an EMI test.
  • \$\begingroup\$ Thanks for the answer, this helped a lot. Would you mind defining "quiescent current" in the context you're using it? I always though the quiescent current is the current an IC consumes/dissipates when the IC is in a no-load or non-switching state: forum.digikey.com/t/… \$\endgroup\$ Feb 21, 2020 at 7:02
  • \$\begingroup\$ Quiescent current is the standby current used by the LT8362 when it is NOT switching, 9µA typical. This is confusing to a lot of people. When the LT8362 is switching, it consumes more than 9µA, probably on the order of mA. That is why burst mode is so helpful. In burst mode the LT8362 stops switching an only monitors the output voltage. When the output voltage drops a little (see figure 2 of that datasheet), the part wakes up and and throws out some switching cycles in order to boost the output back up. The larger the inductor & output cap, the longer the LT8362 can stay asleep. \$\endgroup\$ Feb 22, 2020 at 18:11
