I have a design on an iCE40 FPGA, I use iCEcube2 to compile the VHDL code and in my design I try to infer two small RAM buffers.
The type of the buffers is as follow :
type MESSAGE_T is array(0 to 31) of std_logic_vector(7 downto 0);
They are then accessed in two separate process, one process writes to buffer A and reads from buffer B, and the other process does the oposite. The idea is that one process recieves messages, while the other sends replies. There's a mechanism normally preventing reading and writing from the same buffer at the same time.
Now on to the actual issue : Symplify pro (part of the suite offered with iCEcube2) correctly infers RAM for the buffers:
 @N: CL134 :"D:\[...].vhd":189:8:189:23|Found RAM received_message, depth=32, width=8
 @N: CL134 :"D:\[...].vhd":196:8:196:20|Found RAM reply_message, depth=32, width=8
That's great ! However just after it seems to remove some redundancy. I get a ton of messages such as
  @W: CL169 :"C:\lscc\iCEcube2.2017.08\synpbase\lib\vhd\std.vhd":1:1:1:2|Pruning unused register received_message_31(7 downto 0). Make sure that there are no unused intermediate registers.
And finally it renounces using the hardware block RAMs but uses registers to simulate it instead.
 @W: FX703 :"d:\[...].vhd":196:8:196:20|Unable to map RAM instance reply_message[7:0] to RAM for technology specified.
 @W: FX703 :"d:\[...].vhd":189:8:189:23|Unable to map RAM instance received_message_1[7:0] to RAM for technology specified.
 @W: FX703 :"d:\[...].vhd":189:8:189:23|Unable to map RAM instance received_message[7:0] to RAM for technology specified.
 @N: MF135 :"d:\[...].vhd":196:8:196:20|RAM reply_message[7:0] (in view: work.test_bitbus(behavioral)) is 32 words by 8 bits.
 @N: MF135 :"d:\[...].vhd":189:8:189:23|RAM received_message_1[7:0] (in view: work.test_bitbus(behavioral)) is 32 words by 8 bits.
 @N: MF135 :"d:\[...].vhd":189:8:189:23|RAM received_message[7:0] (in view: work.test_bitbus(behavioral)) is 32 words by 8 bits.
 @N: MF794 |RAM received_message[7:0] required 768 registers during mapping
The problem is that it doesn't tell me at all WHY it's unable to map RAM instance. This is not per-se catastrophic as the design can still work, but it is very wasteful of FPGA ressources and makes routing long and difficult.
EDIT : As for how the registers themselves are accessed, the code is actually quite complex and long so it'd be pointless to post it entirely here. I tried basically 2 methods.
The first method is made of synchronous processes.
process(reset, clk)
begin
  if reset='1'
       ....blah blah blah...
  elsif rising_edge(clk)
  then
     case ...
     when XXX =>
         receive_message(aaa) <= bbb;  -- Some mutually exclusive reads and write to RAMs
         ccc <= reply_message(ddd);
     when YYY =>
         if eee=0
         then
            receive_message(fff) <= ggg;
            jjj <= reply_message(kkk)
         else
            receive_message(lll) <= mmm;
            nnn <= reply_message(ooo);
      ...   --- A dozen of other cases
  end if;
end process
The second method I tried (with only one of the two processes) was to make the process artificially computational (even though this very significantly complexities the code which is already complex) in order to explicit the SRAM address and data lines.
process(...AAA, BBB, CCC, DDD, sensitivity list here ....)
begin
   next_BBB <= BBB;              -- By default registers retain the same value
   next DDD <= DDD;
   receive_message_adr <= 0;      -- Dummy default value
   case ... =>
   when XXX =>
         receive_message_adr <= AAA;       -- Explicit address and data bus for RAM access
         next_BBB <= received_message_data;
   when YYY =>
         reply_message_adr <= CCC;
         next_DDD <= received_message_data;
   ...         -- A dozen of other cases
end process;
-- Explicit asynchronous SRAM read for above thread
process(received_message, received_message_adr)
begin
    received_message_data <= received_message(received_message_adr);
end process;
-- Explicit update to registers for logic described in above thread
process(reset, clk) is
begin
      if reset='1'
          ...blah blah blah....
      then
           BBB <= next_BBB;
           DDD <= next_DDD;
           ... a sh*tload of similar statement involving "next" signals
      end if;
end process;
Unfortunately, despite the added complexity (and decreased readability) in the code, the results were still the same, unable to map to RAM instance. I did not try this for both buffers simultaneously but only one of them. Reason for this is that one of the process is quite more complex, so it's harder to turn it into a computational process involving "next" signals.
  • \$\begingroup\$ Could you show both the read and write code? \$\endgroup\$
    – DonFusili
    Feb 20, 2020 at 11:12
    \$\begingroup\$ Don't know about Lattice, but usually there is some doc like a "synthesis style guide" for an FPGA family with templates that will infer correctly. Follow those in terms of what to do with resets, address and data registers, and so on. \$\endgroup\$
    – user16324
    Feb 20, 2020 at 11:51
    \$\begingroup\$ Having now seen the code I suggest writing an entity that models JUST the memory (no other logic) as a single synchronous process ( + asynchronous read if the technology allows that) and getting that to synthesise. Just read_addr, read_data, write_addr, write_data, write_en (reset and read_en optional), clock. If successful, interface your state machine to that. Synth tools may be "tuned" to recognise simple patterns like that, and transform them into BRAM. \$\endgroup\$
    – user16324
    Feb 20, 2020 at 13:28
  • \$\begingroup\$ Yeah, both the simple and complex code structures don't have correct read address to data delivery delays, Brian's solution will solve that. \$\endgroup\$
    – DonFusili
    Feb 20, 2020 at 13:38
    \$\begingroup\$ @Bregalad Yes, but it would describe a RAM that could actually exist on your FPGA. \$\endgroup\$
    – DonFusili
    Feb 21, 2020 at 8:34
In general, if things keep on not working, open the documentation and follow the synthesis style guide which will show you the exact VHDL/verilog you need to write to infer your favorite blockRAM.
That said, you should be able to write a simple behavioral model for easy cases such as this, as long as you follow the datasheet for the iCE40 family, which says clearly:
In all the sysMEM RAM modes, the input data and addresses for the ports are registered at the input of the memory array.
which can also be found in the timing diagrams of the Memory Usage Guide for the iCE40 Devices. Given a read address and read enable on the rising edge of your read-clock, the data will be available in the output register a fixed time later (so no extra reclocking is required internally).
Behavioral models that describe an input register for the read address, read enable and an output register for the read-data should correctly be inferred to a RAM (that might not meet timing because of the fixed time delay).
Your current read logic does neither.
Good luck.
  • \$\begingroup\$ I've just checked my answer against the recommended code in the Memory Usage Guide, it gives the exact code described here. It's the same behavioral code that can be used for simple enough pseudo dual port rams in contemporary tools for both largest FPGA vendors. \$\endgroup\$
    – DonFusili
    Feb 21, 2020 at 8:52
  • \$\begingroup\$ So this means the read adress should come directly from a register, without any combinational logic inbetween ? But there's no such a constraint for write address ? \$\endgroup\$
    – Bregalad
    Feb 21, 2020 at 16:02
