Im beginner FPGA Designer.
I need to interface the ADC component: ADS5463. datasheet: http://www.ti.com/lit/ds/symlink/ads5463.pdf with a FPGA (lattice ecp3).
I need suggestions how to start implementig it.
From my understanding all I need to do is State Machine based on the timing table and graph given by the datasheet:
and to understand the inputs & outputs of this ADC, espcially the digital signals: (clk, dry, d[11:0], ovr)
I wrote a body for the verilog code.. but still think how to really write the logic:
module top(
input clk, //clock input = 250MHz
input rst,
output reg dry, //DRY
output reg ovr, //OVR
output reg [11:0] d_o; //D[11:0]
reg [5:0] cs, ns;
localparam idle = 6'b000001,
start = 6'b000010,
busy = 6'b000100,
read_middle = 6'b001000,
read_end = 6'b010000,
done = 6'b100000;
//clock input = 250MHz -> Ts=1/fs=4ns
localparam t_aperture = 200 , //200ps
latency = 8 , //3.5 input clock cycles -> 8 rising+falling edges of clock
t_dry = 1600, //950-1600ps CLK to DRY delay
t_data = 2100, //750-2100ps CLK to DATA/OVR delay
t_skew = 650 ; //-350-650ps: t_data-t_dry: DATA to DRY skew.
always @(posedge clk or posedge rst)
if (rst) begin
cs <= idle;
end else begin
cs <= ns;
end
if (rst) begin
ns = idle;
dry = 1'b0;
ovr = 1'b0;
d_o = 12'b000000000000;
end else begin
case (curr_state)
idle:
start:
busy:
read_middle:
read_end:
done:
endmodule
My Questions:
what is my job in this kind of design? I need to write onyl state maching based on timing table and connect all the inputs/outputs to the FPGA andd I'll see the right results?
based on the datasheet, on which signals I should have control of? for example DRY is signal which the ADC produce and I should use in my code or I should control it logic levels in my code => take the CLK divide it by 2 and delay it to the middle of the clock?
any Idea how I should build my state machine? seems like I need 3-4 states here: IDLE, BUSY, DONE. any idead how i create 200ps delay with 150-250MHz clk? i thought about just make 1 clk cycle of delay and it will do just fine.. maybe a bit slower that what the datasheet recommends but safe and works.
I would be very glad for any good explanation or piece of code for how to start to do it.
Thanks!!
