I have a tire balancer circuit board I'm trying to fix and am having trouble figuring out if I can get one of these (pic included). I believe it's a transformer but I'm not sure its ratings and such. I know I need a new capacitor also but I found those available online for 50 cents. The numbers on top read 71142 A and the side reads HI-POT OK.
It’s a common-mode choke (noise filter, not a transformer per se.)
That said, it might make more sense to replace the entire power supply than to attempt to repair it yourself. That unit was subjected to a severe stress - overvoltage surge probably - and likely has other damage that you’ve yet to find.
Power supplies are cheap; your personal safety is not.
That is not a transformer. It is a common mode suppression choke.
  • \$\begingroup\$ thank you! I would have never known that. Do you know where I may be able to purchase one? \$\endgroup\$ Feb 20, 2020 at 17:22
  • \$\begingroup\$ From any shop that sells electronic components, maybe? What shops did you search and not found any? \$\endgroup\$
    – Justme
    Feb 20, 2020 at 17:25
