For the past 4 days, I've been trying to locate this socket, but I'm really struggling. This is now my 3rd attempt at getting help, so I would really appreciate someone more technical, that could help locate/identify it. I've tried searching for the numbers/logos, but can't seem to find anything with google/bing.
The information on the front of the sensor reads: "PT052-N-C4-V1 (IDT?) MK 1820 20180227 142", & the back reads: "PT052-N-S8_V1 180228 (IDT?) 1820 MK".
The closest thing I could find on this topic was another question on StackExchange located here. That lead me down a deeper hole, & I think I may be really close, but I'm not sure. These are the two products I've found that look like they would work. AXT514124 | F4S(0.4mm pitch) & Molex 5024261430
The Header has two rows of 7 pins each, for a total of 14 pins. The pin pitch is 0.35mm-0.4mm. I'm fairly confident that it's 0.4mm, but I would like to find both a 0.35mm & a 0.4mm connector, just to make sure one of them works.
This is the part from iFixit It's a Google Pixel 3 XL Left Pressure Sensor. enter image description here
This is a closeup of the header with a little more information on it. It looks like it says "1b" & "H?5". Not sure if that info is relevant. enter image description here
This photo is the dimensions of the header. The whole size is 4.75mm x 1.25mm. The negative space inside the header measures in at 3.35mm x 0.8mm. enter image description here
So after it being pointed out (Thanks, brhans & Dave Tweed) that this is a Hirose header, I've been looking at their lineup & nothing really seems to be matching up all the way. The BM23PF is closest header I could find that somewhat matches my dimensions. I strongly believe this has to be a 0.4mm pin spacing.
This is the BM23PF overplayed onto my header. enter image description here
    \$\begingroup\$ The left marking is a stylized "HRS" for Hirose \$\endgroup\$
    – brhans
    Feb 21, 2020 at 18:41
It looks like a Hirose BM23PF to me.
The shape of the metal bits on the ends appears to match closely with your photo and the dimensions look fairly close to what you've measured.
Digikey link
  • \$\begingroup\$ Brhans, I added an edit to my original post, detailing the BM23PF. \$\endgroup\$ Feb 22, 2020 at 1:41
Since that looks a lot like the Hirose logo, I checked their website and quickly found the BM46 series connectors, which seem to match your photo and description fairly closely. It's possible that you're looking at a custom variation of this standard part.
Hirose BM46
  • \$\begingroup\$ Dave, I appreciate being pointed in the right direction, but these seem to have come out after the Google Pixel 3. They were announced at CES in 2019. \$\endgroup\$ Feb 22, 2020 at 1:45
Molex also has a line called SlimStack for board to board connectors.
  • \$\begingroup\$ I've already looked at molex yesterday, but I went through all of them & downloaded the 3D models of each socket/header that had 14 pins & compared to my model. Unfortunately they don't seem like they would match up. \$\endgroup\$ Feb 22, 2020 at 1:43
