Several years ago I've tried to find answer to this question but I couldn't find the answers. I hope you help me.
Because my job I have to discharging constantly "big" capacitors ( 400 vdc, 300 vdc, and so on). Ok really they aren't so big but problem is sometimes when I shortcircuit the capacitors , they to make huge sparks.
I have to avoid sparks mostly because several time I've damages IC's very importants into the circuit, and second I'm afraid of the sparks every time I shortcircuit a "big" capacitor Jaja.
So my idea was to conect a parallel resistor to capacitors . Problem is How to calculate the resistor to descharging quickly the capacitors but also avoiding the sparks.
For example:
$$C=100uf -160vdc; R=470 ohm$$
$$Vc = vo*e^{-t/T}$$
$$ vo=160 v$$ $$ T=r*c$$ $$T=100uF *470 ohm$$ $$T=47mS$$
$$vc = 160*e^{-t/0.047}$$
Wao, this discharge very fast : five tao = 5*0.047 = 235mS to discharge the capacitor
This is result:
no sparks
NO sparks
But I need more quickly so I try a 100 ohm resistor
$$C=100uf -160vdc; R=100 ohm$$
$$ vo=160 v$$ $$ T=r*c$$ $$T=100uF *100 ohm$$ $$T=0.01mS$$
$$vc = 160*e^{-t/0.01}$$
Wao, this discharge is faster : five tao = 5*0.01 = 50mS to discharge the capacitor
But this is problem : sparks
sparks
This is a litle spark. Problem is when I discharge bigger capacitors 300 vdc, 400 vdc, etc.
Are they some formule for trade-off quickly discharge and minimun sparks ?
Thank you.
You could use an NTC resistor, the same kind used to limit inrush current on power supplies (hint: they're used to limit the charging current to the input caps.)
An NTC will start at a high resistance, then heat up and lower its resistance as it discharges the cap. This is kind of what you want to avoid sparks.
  • \$\begingroup\$ Thank you. Now I know the NTC resistors \$\endgroup\$ – NIN Jul 13 '20 at 3:17
