I bought some 433mhz senders and receivers and some 433 mhz antennas. Unfortunately I don't know where to solder the antennas.
Where do I solder the antennas to and do I need special solder wire?
Pictures of the sender module
front, back
Sender front Sender back
Pictures of the receiver module
front, back
Receiver front Receiver back
I tried to solder an antenna onto the sender (into the hole in the bottom left hole in the front picture), this resulted in the signals no longer being sent correctly. I could see that data was sent because the receiver did receive data, but it was not the data i sent with the sender.
  • \$\begingroup\$ The datasheet supplied with the TX and RX should explain. They should also explain why the TX has a missing inductor compared with the one in the listing. If there isn't any such data, learn the rule : no datasheet, no sale. \$\endgroup\$ Feb 22, 2020 at 14:48
  • \$\begingroup\$ @BrianDrummond looks like the small coil is the antenna, the one missing on the TX module. \$\endgroup\$
    – jaskij
    Feb 22, 2020 at 19:05
