I am designing a driver for a sensorless bldc motor and I have found these two types of motor configurations. I attach images.
Img 1:
Img 2:
Both are bldc sensorless motors?
How can I know the difference between one physically?
If the 3 power cables and 3 smaller ones come out of a motor, are we talking about the configuration of image 2 and if only 3 of the configuration of image 1 come out?
  • \$\begingroup\$ The second one has sensors, hall sensors to be precise. \$\endgroup\$ Commented Feb 22, 2020 at 14:07
  • \$\begingroup\$ @MarkoBuršič has it : one of those sensorless motors isn't sensorless. But if you need sensorless, ignore the sensors. \$\endgroup\$
    – user16324
    Commented Feb 22, 2020 at 14:50
Q: Both are bldc sensorless motors?
A: No, only the first one is a sensorless BLDC motor. The motor in image 2 has three Hall sensors (the ones enclosed in your red circle), thus it's not sensorless.
Q: How can I know the difference between one physically?
A: If you were to open up a sensored BLDC motor you will find three Hall sensors inside. A sensored BLDC motor also has 3 "small" cables for the signals of the Hall sensors, whereas a sensorless BLDC motor has only the three "thick" power cables.
Q: If the 3 power cables and 3 smaller ones come out of a motor, are we talking about the configuration of image 2 and if only 3 of the configuration of image 1 come out?
A: Exactly
By the way, if you're designing a sensorless inverter you don't need to use the Hall sensor signals, you can just only ignore them.
    \$\begingroup\$ The sensor cable usually has at least 5 wires because the Hall sensors need power. \$\endgroup\$ Commented Feb 22, 2020 at 18:36
    \$\begingroup\$ You're right, thanks for the comment, I was just restricting the discussion to the presence/absence of the signal wires of the Hall sensors. \$\endgroup\$ Commented Feb 23, 2020 at 11:15
