hey there I am looking all over the internet for something like an OS (operating System) or either a software that can be programmed as we program a PLC. and for inputs and outputs we use parallel port using flipflops we read and write the inputs and outputs either 16bit or 8bit.
  • \$\begingroup\$ Your question is not clear and lacks proper capitalisation and punctuation. Product recommendations are off-topic. Voting to close. Make a major edit if you wish to keep it open. \$\endgroup\$
    – Transistor
    Feb 22, 2020 at 17:25
  • \$\begingroup\$ Codesys, however you'll find it hard to work with for PC, and it isn't really an "OS". \$\endgroup\$
    – Ron Beyer
    Feb 22, 2020 at 18:19
    \$\begingroup\$ Have you seen the OpenPLC Project? \$\endgroup\$
    – Ben Miller
    Feb 22, 2020 at 22:56
  • \$\begingroup\$ @BenMiller-ReinstateMonica That's former Beremiz, isn't it? \$\endgroup\$ Feb 23, 2020 at 19:20
  • \$\begingroup\$ @Transistor be patient. not everyone in this world is natively English speaking. and I thought that was the way to be specific and to the point. someone with common sense and knowledge about my question will understand perfectly what i'm talking about. sorry i had to be rude.... \$\endgroup\$
    – Ahmad
    Feb 25, 2020 at 16:17
You need an extension to the OS, c: alled real time kernel. In windows world it's called intervalzero, Linux has many others: RT-Linux, RTAI, preeemption POSIX,...Then you need a software or C code running in the real time kernel. This is Codesys, but also some free source like Matplc (however I don't know if still alive), ClassicLadder,..
