Im trying to build ADC interface with FPGA.
Im using ADS5463: http://www.ti.com/lit/ds/symlink/ads5463.pdf
time diagram: enter image description here
after getting some help here I wrote a simple verilog code that just waits to DRY which is the adc clk to rise and output the data, here is my code:
module top(
    input rstn,
    input dry_i,               //DRY=fs/2 -> fs=160Mhz -> DRY=80MHz
    input ovr_i,
    input [11:0] d_i,
    output reg ovr_o,
    output reg [11:0] d_o
    reg [2:0] cs, ns;
    reg dry_i_r;
    reg [11:0] d_o_r;
    reg ovr_o_r;
    reg rst;
    localparam  idle        = 3'b001,
                busy        = 3'b010,
                done        = 3'b100;
    always @(posedge dry_i or negedge rstn)
    begin
        rst <= ~rstn;
    end
    always @(posedge dry_i or posedge rst)
    begin
        if (rst) begin
            cs <= idle;
        end else begin
            cs <= ns;
        end
    end
    begin
        if (rst) begin
            ns = idle;
            d_o_r  <= 12'b000000000000;
        end else begin
            case (cs)
                idle: begin
                    ns = busy;
                end
                busy: begin
                    if (dry_i) begin
                        d_o_r[11]   <= ~d_i[11];
                        d_o_r[10:0] <= d_o_r[10:0];
                        ovr_o_r <= ovr_i;
                        ns = done;
                    end else begin
                        ns = idle;
                    end
                end
                done: begin
                    d_o <= d_o_r;
                    ovr_o <= ovr_o_r;
                    ns = idle;
                end
                default: begin ns = idle; end
            endcase
        end
    end
endmodule
The reson why I inverted the MSB is because i read here: https://en.wikipedia.org/wiki/Offset_binary
that inverting the MSB converts it to 2s compliments which is easier to work with in Matlab later..
I get from the Analyzer (debugging tool from Lattice) this waveform: enter image description here
which is seems like just a stable while I provding sine wave for the ADC.
another simulation made it just go from 000 to 800 which also seems not right
Any idea how to make it work? How you would wrote this ADC Interface code?
Edit:
after the help and a little more thinking.. I just made the code very straight forward and simple.. and I get the sine wave I wanted in the Matlab simulation (binary to decimal and substract by 2048):
new code:
module top(
    input rstn,
    input dry_i,
    input ovr_i,
    input [11:0] d_i,
    output  led_clk,
    output reg  led_data8,
    output reg ovr_o,
    reg rst;
    reg  [25:0] adc_clk_count   = 26'b0;
    begin
        rst <= ~rstn;
    end
    //LEDS FOR OUTPUT TESTING:
    assign led_clk      = adc_clk_count  [25];
    begin
        if(~rstn) begin
            adc_clk_count   <= 26'b0;
        end else begin
            adc_clk_count   <= adc_clk_count + 1'b1;
        end
    end
    begin
        if(~rstn) begin
            led_data8   <= 1'b0;
        end else begin
            led_data8   <= 1'b1;
        end
    end
    always @(posedge dry_i, posedge rst)
    begin
        if (dry_i) begin
        if (rst) begin
            d_o   <= 12'b100000000000;
            ovr_o <= 1'b0;
        end else begin
            d_o   <= d_i;
            ovr_o <= ovr_i;
        end
        end
    end
endmodule
digital simulation:
matlab simulation (analog):
my next challange is to make it work with DDR clk.. I will ask another questions in the future if I will need more help, thanks for now.
    \$\begingroup\$ See answer in near-duplicate question electronics.stackexchange.com/questions/482784/… \$\endgroup\$ – Brian Drummond Feb 23 at 18:37
  • \$\begingroup\$ ok thanks, but still I get an idea how to understand this output (by inverting MSB and read it as 2s compliment), I need help with understanding what could go wrong with the code.. because the sine wave as analog input and the sampling clock are working and the ADC chip is working (I have leds that blinking for important signals changes) \$\endgroup\$ – Michael Astahov Feb 23 at 18:46
  • \$\begingroup\$ Well I can't see any of that in your simulation so I don't know what you mean by "working". I can't see your sinewave, the equivalent code you expect in 12 bit digital format, or even the clock signal. All I can see is a few LSBs changing on a signal around midscale. So I'm completely in the dark. \$\endgroup\$ – Brian Drummond Feb 23 at 19:00
    \$\begingroup\$ There is an error in your block of code right after if (dry_i) begin that causes your 000/800 errors. Also, inverting the MSB does not convert a value to two's-complement. \$\endgroup\$ – Elliot Alderson Feb 23 at 23:12
  • \$\begingroup\$ wow thanks for see this mistake, I probably was already very tired yesterday. And I think inverting the MSB does convert it to 2s compliment binary represantation (look at the Wiki page I attached), but in second think.. I leave it in offset binary.. in Matlab I will just convert binary to decimal and subtract by 2048 and will get the real number. \$\endgroup\$ – Michael Astahov Feb 24 at 6:20
