Is it possible to use a highspeed (HS) CAN interface for listening to a lowspeed (LS) CAN bus? If so - Is it in any way questionable to do so in a real world car or moped?
As far as I know, LS CAN supports failsafe operation when one signal is broken. I assume, this will not be supported by a HS transceiver.
In my application, I can insure (by means of hard- and firmware measures) that my device is not writing messages to the CAN bus.
So, which risks should I keep in mind when listening on a LS CAN bus?
  • \$\begingroup\$ I'd make/buy an adapter with two transceivers that converts from one physical bus to the other. Data link layer should be identical, just not the signal levels. \$\endgroup\$
    – Lundin
    Commented Feb 24, 2020 at 14:01
High-speed CAN (ISO 11898-2) and Low-speed CAN (ISO 11898-3) are different in physical layer.
They are not electrically similar. I do not recommend using a HS transceiver on a LS bus.
High-speed CAN:
Low-speed CAN:
(source)
  • \$\begingroup\$ Would you see a risk that a HS transceiver interferes with the LS-bus traffic? I only want to sniff, not transmit. \$\endgroup\$
    – Simon
    Commented Feb 26, 2020 at 8:23
