10
I'm shopping for capacitors, and I expect good capacitor datasheets to have a graph of |Z| (the magnitude of the capacitor's impedance) as a function of frequency.
I was confused when I looked at page 2 of this datasheet for a Murata 10nF ceramic capacitor. There are 2 different graphs for the capacitor's impedance as a function of frequency. One graph says it is displaying |Z|, whereas the other graph says it's displaying "R". Obviously the 2 graphs are different, but what's the meaning of the second one? Is it ESR?
I googled around, but all I can find are descriptions of impedance.
  • \$\begingroup\$ Huh. Good question. I never noticed that ESR varied with frequency. I always just kidn of tuned it out when looking at the impedance curve. I guess that means there is a real power loss that is frequency dependent? \$\endgroup\$ – DKNguyen Feb 24 at 18:58
  • \$\begingroup\$ I don't think it's ESR cause the order of magnitude doesn't line up (I've never heard of a ceramic with 10 - 100 ohms ESR). I also have no idea why ESR would vary so much in a ceramic over freq. Then again, I'm not a chemist lol. Could just be a badly edited datasheet. \$\endgroup\$ – johnny_boy Feb 24 at 19:02
  • \$\begingroup\$ I don't think it's the datasheet...unless all of Murata's datasheets are that way. Because they are. \$\endgroup\$ – DKNguyen Feb 24 at 19:03
    \$\begingroup\$ @DKNguyen Those are dielectric loss. The permittivity can be a complex number. The loss will increase with frequency to reach a maximun and than diminish as the frequency increase passing a certain point. \$\endgroup\$ – MathieuL Feb 24 at 19:04
    \$\begingroup\$ @johnny_boy Yes, I am pretty sure this is the ESR. ESR mean equivalent serial resistance. This include all the loss from all the effects present in the capacitor. ESR make it easier to have a lump resistance that represent the loss at different frequency. \$\endgroup\$ – MathieuL Feb 24 at 19:08
10
Impedance (\$Z\$) has both resistive and reactive components:
$$Z = R+jX$$
So if the ESR is small compared to the reactance of the capacitor (as it should be, especially for low frequencies) then \$\left|Z\right|\$ has almost nothing to do with ESR, and almost everything to do with \$jX_c = \frac{1}{j\omega C}\$.
At high frequencies, although it isn't a desirable characteristic, the inductive reactance of the part tends to dominate \$Z\$, and again the ESR becomes mostly irrelevant to determining \$\left|Z\right|\$.
Yes, the second curve is giving ESR. This is important in many applications, because even though it doesn't much affect the behavior of the circuit, it does affect how much the capacitor self heats, as well as the Q factor of any resonator using the capacitor as a component.
|improve this answer|||||
It's a combination of ESR and dielectric losses lumped together and computed as a series resistance to the capacitor. So, at 100 Hz the capacitive reactance is around 160 kOhms and the series loss resistor is around 700 ohms i.e. a Q of around 230.
At 100 kHz Q has dropped to around 100 and keeps falling until self resonance is arrived at and, beyond the SRF, the capacitor is inductive.
Searching internet on the terms: "murata capacitor impedance resistance" gives me as first hit:
https://www.murata.com/en-eu/products/emiconfun/capacitor/2013/02/14/en-20130214-p1
Today's column describes frequency characteristics of the amount of impedance |Z| and equivalent series resistance (ESR) in capacitors.
Understanding frequency characteristics of capacitors enables you to determine, for example, the noise suppression capabilities or the voltage fluctuation control capabilities of a power supply line. Frequency characteristics are therefore important parameters that are essential for circuit design. This column describes two types of frequency characteristics: impedance |Z| and ESR.
ESR also shows frequency characteristics for values equivalent to loss.
Likewise, the datasheet also gives impedance |Z| and ESR
