I am struggling to make a cockpit for my home-made flight simulation.
How can I connect this toggle switch to an Arduino Uno:
Tries:
I connected one end to "Ground" another to "VCC" and middle one to any analog pin. But it turns off the Arduino.
Please help me to connect this switch correctly.
  • \$\begingroup\$ it is a switch, similar to a pushbutton ... have you searched the web for tutorials? \$\endgroup\$
    – jsotola
    Feb 26, 2020 at 6:19
  • \$\begingroup\$ Yes but nothing works. Please help me if it can be connected as similar to pushbuton and I want to get it's state 0 or 1 \$\endgroup\$
    – Ibnelaiq
    Feb 26, 2020 at 6:20
  • \$\begingroup\$ You are likely connecting the switch incorrectly, so the switch is connecting vcc directly to ground \$\endgroup\$
    – BeB00
    Feb 26, 2020 at 6:27
  • \$\begingroup\$ nothing works is a meaningless description of a problem ... please update your post with a description of how you connected the switch, the code that you used, what you expected to happen and what actually did happen \$\endgroup\$
    – jsotola
    Feb 26, 2020 at 6:30
  • \$\begingroup\$ Show a photo. You don't need an analog input. It's on/off so a digital input is all that is required. Again, describe what exactly happens when you toggle the switch. \$\endgroup\$
    – Transistor
    Feb 26, 2020 at 7:21
Arduino related question goes here: Arduino SE.
#define switch 3
void setup(){
 pinMode(switch, INPUT_PULLUP);
void loop(){
 if(switch == LOW){
  do this;
 } else {
  do that;
Edit:
  • \$\begingroup\$ please tell me how I connect these 3 legs of toggle switch. I want the 0 or 1 from it \$\endgroup\$
    – Ibnelaiq
    Feb 26, 2020 at 8:46
    \$\begingroup\$ @AhmedAli see the edit. \$\endgroup\$ Feb 26, 2020 at 9:42
  • \$\begingroup\$ Thanks for helping \$\endgroup\$
    – Ibnelaiq
    Feb 26, 2020 at 9:47
  • \$\begingroup\$ and will I have to connect 3 leg to vcc or not \$\endgroup\$
    – Ibnelaiq
    Feb 26, 2020 at 9:52
    \$\begingroup\$ No, don't connect the third leg to anything. \$\endgroup\$ Feb 26, 2020 at 9:54
